Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Adding other controls to a ToolBar
Adding other controls to a ToolBar [message #902711] Mon, 20 August 2012 00:00 Go to next message
Eclipse User
I must admit upfront to being pretty clueless about Java and SWT. In an
attempt to learn I'm trying to port a small C# program and immediately
found the GUI construction...erm...interesting.
So, is it possible to shoehorn other controls into a ToolBar (in this
case a label and a progress bar) or do I just place these controls over
an equal-sized separator in the toolbar to simulate the effect?
It's a fixed size window, so that makes the layout simpler at least.
S e á n Ó S é a g h d h a sean.anseo [at] gmail.com
Go mbéadh seacht shliocht ag sliocht do shleachta. Rabhlóg.
Re: Adding other controls to a ToolBar [message #902915 is a reply to message #902711] Tue, 21 August 2012 03:15 Go to previous messageGo to next message
Jan Krakora is currently offline Jan Krakora
    Display display = new Display();
    Shell shell = new Shell(display);
    ToolBar toolBar = new ToolBar(shell, SWT.HORIZONTAL);
    Combo combo = new Combo(toolBar, SWT.READ_ONLY);
    ToolItem comboItem =
        new ToolItem(toolBar, SWT.SEPARATOR);
    comboItem.setControl(combo);
    comboItem.setWidth(64);
    for (int i = 0; i < 2; i++) {
        ToolItem item = new ToolItem(toolBar, SWT.PUSH);
        item.setText("Push " + i);
    toolBar.pack();
    shell.pack();
    shell.open();
    while (!shell.isDisposed()) {
        if (!display.readAndDispatch()) display.sleep();
    display.dispose();
Re: Adding other controls to a ToolBar [message #903214 is a reply to message #902711] Wed, 22 August 2012 10:10 Go to previous message
Oliver Koch is currently offline Oliver Koch
Member
Am 20.08.2012 06:00, schrieb Seán Ó Séaghdha:
You might want to consider using the WindowBuilder feature for eclipse
Previous Topic:active CTabItem
Next Topic:[OLEAutomation]retrieving data from a VT_ARRAY
Current Time: Mon May 20 12:48:27 EDT 2013
Powered by FUDForum. Page generated in 0.03935 seconds
