I just downloaded Eclipse IDE for Java EE Developers 32bit 4.2
but I cannot connect to update sites (time out).
My pc uses Win 7 32 bit, I used the JDK 1.6.0_29 and JDK 1.7.0_05
I'm behind a NTLM proxy but I can navigate with the internal browser and the 3.7 version of Eclipse is working fine (same setup).
In the eclipse.ini I used (as suggested on some sites):
-Djava.net.preferIPv4Stack=true
-Djava.util.Arrays.useLegacyMergeSort=true
But nothing worked for me
The problem is:
- Opening the MarketPlace
Root exception:
org.eclipse.core.runtime.CoreException: Unable to read repository at http://marketplace.eclipse.org/catalogs/api/p.
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.stream(RepositoryTransport.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.epp.internal.mpc.core.util.AbstractP2TransportFactory.invokeStream(AbstractP2TransportFactory.java:35)
at org.eclipse.epp.internal.mpc.core.util.TransportFactory$1.stream(TransportFactory.java:69)
at org.eclipse.epp.internal.mpc.core.service.RemoteMarketplaceService.processRequest(RemoteMarketplaceService.java:141)
at org.eclipse.epp.internal.mpc.core.service.RemoteMarketplaceService.processRequest(RemoteMarketplaceService.java:80)
at org.eclipse.epp.internal.mpc.core.service.DefaultCatalogService.listCatalogs(DefaultCatalogService.java:36)
at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCommand$3.run(MarketplaceWizardCommand.java:200)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(SocketInputStream.java:129)
at java.io.BufferedInputStream.fill(BufferedInputStream.java:218)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:258)
at java.io.BufferedInputStream.read(BufferedInputStream.java:317)
at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:695)
at sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:640)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1195)
at org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnectionRetrieveFileTransfer.getDecompressedStream(UrlConnectionRetrieveFileTransfer.java:542)
at org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnectionRetrieveFileTransfer.openStreams(UrlConnectionRetrieveFileTransfer.java:312)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:879)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:570)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:422)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.read(FileReader.java:273)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.stream(RepositoryTransport.java:172)
... 11 more
- Install new software
Unable to read repository at http://download.eclipse.org/releases/juno/compositeContent.jar.
- check for Update
Some sites could not be found. See the error log for more detail.
Unable to read repository at http://download.eclipse.org/technology/m2e/releases/compositeContent.xml.
Read timed out
Unable to read repository at http://download.eclipse.org/eclipse/updates/4.2/compositeContent.jar.
Read timed out
Unable to read repository at http://download.eclipse.org/webtools/repository/juno/compositeContent.jar.
Read timed out
Read timed out
Unable to read repository at http://download.eclipse.org/mylyn/releases/juno/compositeContent.xml.
Read timed out
Unable to read repository at http://download.eclipse.org/libra/releases/R-0.1.0-201106071417/content.jar.
Read timed out
Some one can please help me?
