Home » Eclipse Projects » Rich Client Platform (RCP) » multiple column table header
multiple column table header [message #901899] Tue, 14 August 2012 22:44 Go to next message
Martin Jacob is currently offline Martin JacobFriend
how can I define a Table or TableView with a multiple column header? I found some thing for JTable
(http://www.crionics.com/public/swing_examples/JTableExamples1.html) but I think it wont work in
Eclipse.
the needed layout is:
|Global header |
|2nd level header A | 2nd level header B |
|3rd level A | 3rd level B |3rd level D | 3rd level E |
|col 1 | col2 |col 1 | col2 |col 1 | col2 |col 1 | col2 |
any idea how to implement this? Any hints would be appreciated, Martin
Re: multiple column table header [message #901923 is a reply to message #901899] Wed, 15 August 2012 05:42 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel KrüglerFriend
> I think it wont work in Eclipse.
You are right, SWT Table cannot represent multiple column headers.
I suggest to consider to use more capable Table framework, e.g. Nebula Grid:
http://www.eclipse.org/nebula/widgets/grid/grid.php
(Take a look at the examples)
or maybe even better NatTable:
http://eclipse.org/nattable/
- Daniel
Re: multiple column table header [message #901925 is a reply to message #901923] Wed, 15 August 2012 06:39 Go to previous message
Thanks Daniel, I just had a look at the websites and it looks very good. Will try it!
Daniel Krügler wrote, On 15.08.2012 07:42:
> - Daniel
Previous Topic:Error when adding rcp-sdk as target platform
Next Topic:Common Navigator Framework
Current Time: Sun May 27 12:13:18 GMT 2018
Powered by FUDForum. Page generated in 0.01687 seconds
