Home » Modeling » EMF » EMF Resources transactional safe?
EMF Resources transactional safe? [message #901484] Mon, 13 August 2012 05:08 Go to next message
Hauke Fuhrmann is currently offline Hauke FuhrmannFriend
Hi there,
is saving EMF Models in Resources safe from an transactional viewpoint,
e.g. in high-availability environments?
I.e. will a file (either XML or binary) get corrupted and not readable
anymore if saving a model is interrupted right in between the save process?
Hauke
Re: EMF Resources transactional safe? [message #901488 is a reply to message #901484] Mon, 13 August 2012 06:06 Go to previous message
Hauke,
Comments below.
On 13/08/2012 7:08 AM, Hauke Fuhrmann wrote:
> Hi there,
> viewpoint, e.g. in high-availability environments?
A resource is saved by opening a stream for the URI, writing the
contents, and then closing the stream. I expect that while a stream is
open, nothing else can open a stream for that same URI and do an update.
> process?
It's possible for a VM to crash, so imagine it's always possible for a
stream to be incomplete at that point.
> Cheers,
> Hauke
Previous Topic:[Teneo] @PrePersist/PreUpdate - Hibernate Interceptors - extension manager
Next Topic:What is the status of XSD roundtrip ?
Current Time: Fri Feb 23 03:16:39 GMT 2018
Powered by FUDForum. Page generated in 0.01616 seconds
