Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Boolean operators in version 3.2
[Acceleo] Boolean operators in version 3.2 [message #901400] Sat, 11 August 2012 15:08 Go to next message
Luís de Sousa is currently offline Luís de Sousa
Member
Dear all,
I need to perform a boolean comparison in an if block. Something like:
[if (class.getTaggedValue(class, 'Stereotype', 'initRandom') == 'TRUE')]
According to the 2.6 reference manual, the following operators should be available (page 9):
== (equal), != (different), < (less than), <= (less or equal than), > (greater than >= (greater than or equal), || (logical or), && (logical and) and ! (negation)
But whenever I use them I get this error: "=" unexpected token(s). Am I doing something wrong? Or have the boolean operators changed since version 2.6?
Thank you,
Luís
Re: [Acceleo] Boolean operators in version 3.2 [message #901455 is a reply to message #901400] Sun, 12 August 2012 11:24 Go to previous messageGo to next message
I've no idea about 2.x, but Acceleo 3.x complies with the OMG MOFM2T
specification that is based on OCL, for which the relational operators are
and the literals are
true, false
Ed Willink
On 11/08/2012 20:08, Luís de Sousa wrote:
> Dear all,
> Quote:
> version 2.6?
> Thank you,
> Luís
Re: [Acceleo] Boolean operators in version 3.2 [message #901522 is a reply to message #901455] Mon, 13 August 2012 04:44 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane Begaudeau
The answer provided by Ed is correct "==" is not valid in Acceleo 3 (use "=" instead). Acceleo 2.x and Acceleo 3.x do not use the same languages so there are some differences. You can have a look at the documentation of the language and all its available operations.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [Acceleo] Boolean operators in version 3.2 [message #901647 is a reply to message #901522] Mon, 13 August 2012 16:01 Go to previous message
Member
Thanks to both for the replies. Using the "=" character things work fine.
Luís
Previous Topic:Questions about generation code for Objective C and small games for iPhone
Next Topic:Acceleo meta-model as namespace
Current Time: Wed Jun 19 00:28:04 EDT 2013
Powered by FUDForum. Page generated in 0.01627 seconds
