Home » Eclipse Projects » JFace » Disable one radio button in a RadioGroupFieldEditor
Disable one radio button in a RadioGroupFieldEditor [message #901185] Fri, 10 August 2012 08:47 Go to next message
Mikael Petterson is currently offline Mikael PettersonFriend
I need to toggle (enable/disable) a radio button in a RadioGroupFieldEditor depending on the value of
my BooleanFieldEditor. Is it possible?
Re: Disable one radio button in a RadioGroupFieldEditor [message #901765 is a reply to message #901185] Tue, 14 August 2012 13:42 Go to previous message
Heiko  Böttger is currently offline Heiko BöttgerFriend
Looking at the code of RadioGroupFieldEditor it seems like there is no way to access the radion-buttons themselves. You can do a dirty hack and invoke the getRadioBoxControl(parent) and access the radiobuttons via the getChildren()-method of the composite (group). However be aware that this hack may break when the code of the RadioGroupFieldEditor changes. If you use the hack, consider to open a feature request in bugzilla for adding a setVisibleMethod or open up the fieldeditor a little bit. May be they could could make the fields at least protected, allowing you to create a subclass.
Best Regards
Previous Topic:Modify indent of tree elements
Next Topic:How to do empty selection (IStructuredSelection.isEmpty() == true)?
Current Time: Tue Mar 20 21:44:25 GMT 2018
Powered by FUDForum. Page generated in 0.01850 seconds
