Home » Modeling » EMF » [Teneo] @PrePersist/PreUpdate - Hibernate Interceptors - extension manager
[Teneo] @PrePersist/PreUpdate - Hibernate Interceptors - extension manager [message #901170] Fri, 10 August 2012 08:13 Go to next message
R Deepak is currently offline R DeepakFriend
I have a timestamp field in my model persisted using Teneo.
I would like this to be automatically updated when hibernate persists the resource to the DB.
What is the best way to do this?
Update:
I am trying to do this via hibernate interceptors. If I manually create a session with
openSession(myInterceptor), it works.
If I set the Interceptor class using the Teneo extension manager,
extensionManager.registerExtension(EMFInterceptor.class.getName(), TimeStampInterceptor.class.getName());
it does not work.
TimeStampInterceptor extends EMFInterceptor..
Is there anyother way to register a sessionFactory wide interceptor?
[Updated on: Fri, 10 August 2012 11:10]
Report message to a moderator
Re: [Teneo] @PrePersist/PreUpdate [message #901299 is a reply to message #901170] Fri, 10 August 2012 16:39 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
The best approach is to use a Hibernate interceptor in this case. See the hibernate documentation for information on
interceptors.
See this older newsgroup thread for info on how to enable this for Teneo:
http://www.eclipse.org/forums/index.php/mv/tree/24266/
gr. Martin
> Thanks
> Deepak
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] @PrePersist/PreUpdate [message #901355 is a reply to message #901299] Sat, 11 August 2012 10:40 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Right we are using an interceptor to track, datetime, workstation and
user information.
For certain objects we even write a changelog which is processed by
daemon processes - if a customer really wants to we can log any change ;-).
Tom
Am 10.08.12 18:39, schrieb Martin Taal:
> the hibernate documentation for information on interceptors.
> gr. Martin
>> Thanks
>> Deepak
Re: [Teneo] @PrePersist/PreUpdate [message #901482 is a reply to message #901299] Mon, 13 August 2012 04:22 Go to previous message
Martin taal wrote on Fri, 10 August 2012 12:39
interceptors.
Thanks. Will try this out..
Previous Topic:How to force generation of Validator
Next Topic:EMF Resources transactional safe?
Current Time: Tue Jun 19 16:43:21 GMT 2018
Powered by FUDForum. Page generated in 0.02034 seconds
