Home » Modeling » TMF (Xtext) » Make my model nodes implement an interface?
Make my model nodes implement an interface? [message #901088] Thu, 09 August 2012 17:26 Go to next message
Dobes Vandermeer is currently offline Dobes VandermeerFriend
I have this horrible piece of code:
	public static class GetDeclName extends AstSwitch<DeclName> {
		@Override public DeclName caseAxiom(Axiom object) { return object.getName(); }
		@Override public DeclName caseCEnum(CEnum object) { return object.getName(); }
		@Override public DeclName caseClass(Class object) { return object.getName(); }
		@Override public DeclName caseCStructDef(CStructDef object) { return object.getName(); }
		@Override public DeclName caseEnumDef(EnumDef object) { return object.getName(); }
		@Override public DeclName caseFun(Fun object) { return object.getName(); }
		@Override public DeclName caseInsertion(Insertion object) { return object.getName(); }
		@Override public DeclName caseInstance(Instance object) { return object.getName(); }
		@Override public DeclName caseLemma(Lemma object) { return object.getName(); }
		@Override public DeclName caseModule(Module object) { return object.getName(); }
		@Override public DeclName caseObjectFunction(ObjectFunction object) { return object.getName(); }
		@Override public DeclName caseParameter(Parameter object) { return object.getName(); }
		@Override public DeclName caseProc(Proc object) { return object.getName(); }
		@Override public DeclName caseReduce(Reduce object) { return object.getName(); }
		@Override public DeclName caseRename(Rename object) { return object.getName(); }
		@Override public DeclName caseStructDef(StructDef object) { return object.getName(); }
		@Override public DeclName caseTheorem(Theorem object) { return object.getName(); }
		@Override public DeclName caseTypeDecl(TypeDecl object) { return object.getName(); }
		@Override public DeclName caseTypedef(Typedef object) { return object.getName(); }
		@Override public DeclName caseTVar(TVar object) { return object.getName(); }
		@Override public DeclName caseUnionDef(UnionDef object) { return object.getName(); }
I'm wonder if I could just have an interface like HasName and convince Xtext to put "implements HasName" on the appropriate nodes.
Is this kind of customization possible?
Re: Make my model nodes implement an interface? [message #901091 is a reply to message #901088] Thu, 09 August 2012 17:39 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
introducing an abstract Rule
Named: Axiom | CEnum | ... | UnionDef ;
doesnt work?
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Make my model nodes implement an interface? [message #901142 is a reply to message #901091] Fri, 10 August 2012 02:09 Go to previous message
That is very smart! Thanks!
Previous Topic:Xtext standalone application beginner tutorial
Next Topic:problem with if expression
Current Time: Thu May 24 17:40:05 GMT 2018
Powered by FUDForum. Page generated in 0.02331 seconds
