Home » Eclipse Projects » GEF » Proble in saving file(Problem in saving file)
Proble in saving file [message #901045] Thu, 09 August 2012 14:11 Go to next message
vrush Mising nameFriend
Member
I have created a sample editor with flyout palette which can add radion button control to the editor. I could drag and drop the radio button from palatte to editor but can not save the file.
Error while saving -
java.io.NotSerializableException: org.eclipse.ui.views.properties.TextPropertyDescriptor
at java.io.ObjectOutputStream.writeObject0(Unknown Source)
at java.io.ObjectOutputStream.writeArray(Unknown Source)
I have implemented an abstract class with interfaces IPropertySource, Cloneable and Serializable.
Please advise me on this. Stuck since long.
Thanks in advance,
Vrushali.
Re: Proble in saving file [message #901152 is a reply to message #901045] Fri, 10 August 2012 06:30 Go to previous message
Jan Krakora is currently offline Jan KrakoraFriend
it means thet the org.eclipse.ui.views.properties.TextPropertyDescriptor is being serialized while it's not implementing the Serializable interface.
You have an instance of it inside your serialized object.
Make it static or transient.
Previous Topic:[Zest] Arrange nodes over the visible range of the view
Next Topic:Default Select, Zoom and Note Palette Icon File/Jar Location?
Current Time: Tue Feb 20 04:22:43 GMT 2018
Powered by FUDForum. Page generated in 0.01866 seconds
