Home » Archived » Eclipse Process Manager (Stardust) » User not found error while running reports in Stardust env(BIRT reporting component issue)
User not found error while running reports in Stardust env [message #900115] Sat, 04 August 2012 07:26 Go to next message
Ganesh Lawande is currently offline Ganesh LawandeFriend
If you get following error in your BIRT reporting component while running Stardust reports, then the issue is likly related to JNDI name is not properely cofigured.
20120730 08:02:24,930 ERROR (WebContainer : 6) ProcessDatabaseQueryServiceEJB - javax.naming.NameNotFoundException: Name comp/env/jdbc not found in context "java:".
20120730 08:02:25,059 INFO (WebContainer : 6) ProcessDatabaseQueryServiceEJB - Worktime calculator class class ag.carnot.reporting.worktime.DefaultWorktimeC
alculator
20120730 08:02:25,059 INFO (WebContainer : 6) Connection - API <=== open()
20120730 08:02:25,060 INFO (WebContainer : 6) Connection - API ===> newQuery()
20120730 08:02:25,060 INFO (WebContainer : 6) Connection - API <=== getMetaData()
20120730 08:02:25,060 INFO (WebContainer : 6) Query - API ===> prepare()
20120730 08:02:25,080 INFO (WebContainer : 6) Query - API <=== prepare()
20120730 08:02:25,080 INFO (WebContainer : 6) Connection - API ===> getMetaData()
20120730 08:02:25,080 INFO (WebContainer : 6) DataSetMetaData - API ===> DataSetMetaData()
20120730 08:02:25,080 INFO (WebContainer : 6) DataSetMetaData - API <=== DataSetMetaData()
20120730 08:02:25,080 INFO (WebContainer : 6) Connection - API <=== getMetaData()
20120730 08:02:25,090 INFO (WebContainer : 6) Query - API ===> executeQuery()
Re: User not found error while running reports in Stardust env [message #900116 is a reply to message #900115] Sat, 04 August 2012 07:30 Go to previous message
Adding correct JNDI ref entries in your app server resolves this issue. The BIRT component looks the currently logged-in user in the session/cache, if it is not found there, it tries to fetch it from the adudit trail DB using configured data source. And hence if JNDI name is not found, it returns the error saying could not find the user.
Previous Topic:Sources eclipse setup
Next Topic:Build the infinity portal
Current Time: Fri Apr 20 05:17:28 GMT 2018
Powered by FUDForum. Page generated in 0.01910 seconds
