Home » Modeling » EMF » Why does EAnnoptation initialization code not set the annotation contents ?
Why does EAnnoptation initialization code not set the annotation contents ? [message #899871] Thu, 02 August 2012 16:03
Philipp W. Kutter is currently offline Philipp W. KutterFriend
I created an annotation with content objects.
My attached Model mypackage.ecore contains 2 instances of class State
inside the "States" annotation for MyRootObject eClass,
but I don't see any attempts in the templates to reflect this in the
generated
MypackagePackageImpl.java which contains the default generated code:
* Initializes the annotations for <b>States</b>.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
protected void createStatesAnnotations() {
String source = "States";
addAnnotation(myRootObjectEClass, source, new String[] {});
the latter call addAnnotation(myRootObjectEClass, source, new
String[] {});
does NOT even try to set the annotation contents.
Why?
Regards, Philipp
Previous Topic:Why does EAnnoptation initialization code not set the annotation contents ?
Next Topic:Why does EAnnoptation initialization code not set the annotation contents ?
Current Time: Mon May 21 23:01:19 GMT 2018
Powered by FUDForum. Page generated in 0.01713 seconds
