Home » Modeling » QVT-OML » Modifying QVT Traceability.
| Modifying QVT Traceability. [message #899805] |
Thu, 02 August 2012 08:06  |
Juan Pedro Silva Messages: 247 Registered: July 2009 |
Hi everybody!.
I'm new to QVT, although not that new to Eclipse plugins, EMF and M2M.
Congratulations on your tool, by the way.
We are planning on using QVTO on a research project now, and we would be
interested in modifying some of its functionality.
In particular, we are interested in using a more customized/elaborated
traceability metamodel that is more adjusted to our particular needs.
I would like to ask, therefore, if there is any extension point in QVTO
where we could plug-in a new traceability metamodel and engine.
One of my partners has already modified QVTO to take the trace model as
input and only create new elements (sort of incremental transformation),
but this implies playing with internal classes.
We would prefer to use a more maintainable extension approach, and that
is the reason behind my question.
Thanks in advance for your help.
JP
| Re: Modifying QVT Traceability. [message #899816 is a reply to message #899805] |
Thu, 02 August 2012 08:42   |
Ed Willink Messages: 3185 Registered: July 2009 |
I doubt that there is such a capability.
QVTo may gradually move to the new Eclipse OCL VM which is more
accurate, faster, flexible and has a Java code generator.
The flexibility might help you one day.
QVTo is short of developers so if you want something special you may
have to help yourself, or join in a collaboration for the future.
Ed Willink
On 02/08/2012 13:06, Juan Pedro Silva Gallino wrote:
> Hi everybody!.
> be interested in modifying some of its functionality.
> QVTO where we could plug-in a new traceability metamodel and engine.
> as input and only create new elements (sort of incremental
> transformation), but this implies playing with internal classes.
> that is the reason behind my question.
> JP
| Re: Modifying QVT Traceability. [message #899824 is a reply to message #899816] |
Thu, 02 August 2012 09:19   |
Thank you, Ed, for your answer.
We might upload a patch or something to a bugzilla enhancement if we
follow this path.
Nonetheless, from your comment on a migration to the new OCL VM I get
that (mayor) changes are expected on internal classes, so this will
probably not be a safe path to follow (having compatibility with future
QVTO versions in mind).
JP
El 02/08/2012 14:42, Ed Willink escribió:
> Hi
> Regards
> Ed Willink
>> Hi everybody!.
>> Regards,
>> JP
| Re: Modifying QVT Traceability. [message #899903 is a reply to message #899824] |
Thu, 02 August 2012 14:25  |
Significant evolution is likely, but not on traceability. If you can
identify a more flexible traceability framework, it could be adopted by
the enhanced QVTo, and possibly QVTc ....
I envision some kind of base model that defines a minimal API.
Ed Willink
> follow this path.
> future QVTO versions in mind).
> JP
>> Hi
>> Regards
>> Ed Willink
>>> Hi everybody!.
>>> Regards,
>>> JP
Current Time: Sun May 26 00:40:41 EDT 2013
Powered by FUDForum. Page generated in 0.03555 seconds
