Home » Archived » EGL Development Tools » EGL EDT(Problem with update of 0.8.1 EDT )
EGL EDT [message #899688] Wed, 01 August 2012 20:52 Go to next message
James R. Martin is currently offline James R. MartinFriend
[RESOLVED] ...I am getting the error:
!SESSION 2012-08-01 15:19:34.286 eclipse.buildId=M20120208-0800
java.version=1.7.0_05
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2012-08-01 15:19:37.697
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.ant.ui.antRunner, org.eclipse.datatools.connectivity.console.profile.StorageFileEditor, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.ecore.Ecore2GenModel, org.eclipse.emf.importer.java.Java2GenModel, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.pde.build.Build, org.eclipse.pde.junit.runtime.uitestapplication, org.eclipse.pde.junit.runtime.legacytestapplication, org.eclipse.pde.junit.runtime.coretestapplication, org.eclipse.pde.junit.runtime.coretestapplicationnonmain, org.eclipse.pde.junit.runtime.nonuithreadtestapplication, org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer, org.eclipse.wst.jsdt.core.JavaCodeFormatter, org.eclipse.wst.server.preview.preview.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
I checked Java Version 1.7.0_05 from Oracle Corporation
is installed and running.
Can anyone tell me how to correct this problem?
James
James R. Martin J. Martin Associates
5185 Tara Ln., Bossier City, LA 71111 - 7810
Phone: (318) 752-4109 Cell Phone: ( 318) 773-9484 Personal e-mail: jmartin@jmartinassociates.net
Web Site: www.jmartinassociates.net
[Updated on: Thu, 02 August 2012 00:25]
Report message to a moderator
Re: EGL EDT [message #899692 is a reply to message #899688] Wed, 01 August 2012 21:07 Go to previous messageGo to next message
Matt Heitz is currently offline Matt HeitzFriend
Member
Hi James,
What are you trying to do when this happens?
Also, how did you install 081? Did you download an all-in-one build or did you use the update site? If you used the update site, are you upgrading from an earlier release of EDT?
-Matt
Re: EGL EDT [message #899693 is a reply to message #899692] Wed, 01 August 2012 21:20 Go to previous messageGo to next message
I downloaded the eglweb-080-win32.zip and deleted the old eclipse and gave a new workspace of K:\EGL_EDT when trying to bring it up.
James
Re: EGL EDT [message #899697 is a reply to message #899688] Wed, 01 August 2012 22:16 Go to previous message
I solved my problem. I had a Java EE IDE installed which I used the instructions at:http://eclipse.org/edt/#download for Update site and it worked.
Problem solved.
James
Previous Topic:EDT 0.8.1 release is now available!
Next Topic:BIRT Report confusion
Current Time: Sun May 27 23:45:57 GMT 2018
Powered by FUDForum. Page generated in 0.01415 seconds
