Home » Proposals » OSGi Enterprise Tools » can't start OSGi need help
can't start OSGi need help [message #899260] Tue, 31 July 2012 09:07 Go to next message
jessusniww Missing name is currently offline jessusniww Missing nameFriend
hi:
Today ,i download a new eclipse version(Eclipse Java EE IDE for Web Developers.
Version: Juno ReleaseBuild id: 20120614-1722).
After start eclipse, i run OSGi framework,it show below errors:
!SESSION 2012-07-31 16:57:35.057 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -dev file:E:/Maqetta New Eclipse/.metadata/.plugins/org.eclipse.pde.core/New_configuration/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -console
!ENTRY org.eclipse.equinox.console 4 0 2012-07-31 16:57:35.916
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.console_1.0.0.v20120522-1841 [10]" could not be resolved. Reason: Missing Constraint: Import-Package: org.apache.felix.service.command; version="0.8.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2012-07-31 16:57:36.181
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.console_1.0.0.v20120522-1841.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2012-07-31 16:57:36.197
!MESSAGE Could not start bundle: org.eclipse.equinox.console
!STACK 0
org.osgi.framework.BundleException: Could not start bundle: org.eclipse.equinox.console
at org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:217)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:297)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.console_1.0.0.v20120522-1841 [10]" could not be resolved. Reason: Missing Constraint: Import-Package: org.apache.felix.service.command; version="0.8.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:215)
... 10 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2012-07-31 16:57:36.197
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-07-31 16:57:36.197
!SUBENTRY 2 org.eclipse.equinox.console 2 0 2012-07-31 16:57:36.197
!MESSAGE Missing imported package org.apache.felix.service.command_0.8.0.
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle org.eclipse.equinox.console_1.0.0.v20120522-1841 [10] was not resolved.
i have no idea ,how to deal with it ,can anyone give me some help?
Re: can't start OSGi need help [message #899700 is a reply to message #899260] Wed, 01 August 2012 23:35 Go to previous messageGo to next message
Warwick Burrows is currently offline Warwick BurrowsFriend
Member
I had the same problem today and added these jars definitions to the osgi.bundles property in my config.ini file and it works now. I found them in my plugins directory they just weren't added to config.ini. If you have different versions of these plugins then try those instead. You may not need the gogo.command plugin but i added it just in case. Don't forget the leading "," as each entry is separated by comma:
,reference\:file\:org.eclipse.equinox.console_1.0.0.v20111215-1210.jar@4,reference\:file\:org.apache.felix.gogo.runtime_0.8.0.v201108120515.jar@4,reference\:file\:org.apache.felix.gogo.runtime_0.8.0.v201108120515.jar@4,reference\:file\:org.apache.felix.gogo.shell_0.8.0.v201110170705.jar@4,reference\:file\:org.apache.felix.gogo.command_0.8.0.v201108120515.jar@4
Warwick
icon7.gif  Re: can't start OSGi need help [message #903557 is a reply to message #899700] Fri, 24 August 2012 10:20 Go to previous message
guokai zhang is currently offline guokai zhangFriend
I have the same problem ,when I set OSGi Framework in Run Configurations,selected only on bundle org.eclipse.osgi and the click run throws Exception like this:
!SESSION 2012-08-24 18:17:30.968 -----------------------------------------------
java.version=1.6.0_23
Command-line arguments: -dev file:E:/OSGI/.metadata/.plugins/org.eclipse.pde.core/qqq/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -console
!ENTRY org.eclipse.osgi 4 0 2012-08-24 18:17:31.453
!MESSAGE Could not find bundle: org.eclipse.equinox.console
!STACK 0
org.osgi.framework.BundleException: Could not find bundle: org.eclipse.equinox.console
at org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:211)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
why ?
how to got it?
I know why it happend. In eclipse 4.2 IDE.the minmix osgi framework need :
org.eclipse.osgi
org.apache.felix.gogo.*(runtime shell command) five plugins
[Updated on: Sat, 25 August 2012 03:32]
Report message to a moderator
Previous Topic:How to Export Dependent Plugins in Eclipse
Next Topic:Migrating my application to OSGi
Current Time: Sat Feb 24 18:45:58 GMT 2018
Powered by FUDForum. Page generated in 0.02232 seconds
