Home » Eclipse Projects » Rich Client Platform (RCP) » Remove Mac Application Menu in RCP application
Remove Mac Application Menu in RCP application [message #898714] Fri, 27 July 2012 10:29 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising nameFriend
I am working with RCP application. Normally when i run my application in MAC OS then there is an extra menu (with the name defined in product file) at first place and then rest of menus defined in application appear. In Windows, this menu does not appear.
I think we can get the reference to his menu by Display.getSystemMenu() but when i try to use setVisible(false) method on the Menu Object then it does not disappear.
This is call application menu in MAC OS world.
I want to remove this Mac OS application menu.
Any idea?
[Updated on: Fri, 27 July 2012 15:17]
Report message to a moderator
Re: Remove Mac Application Menu in RCP application [message #899086 is a reply to message #898714] Mon, 30 July 2012 14:08 Go to previous messageGo to next message
Joseph Carroll is currently offline Joseph CarrollFriend
Could you share a sample application. That sounds intriguing and I would like to take a look.
JD
Re: Remove Mac Specific Menu in RCP application [message #899136 is a reply to message #898714] Mon, 30 July 2012 15:58 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
You can't remove this menu - it is from the OS.
Tom
Am 27.07.12 12:29, schrieb ModelGeek Mising name:
> Normally this menu contains menu items like "Preferences", "Services",
> "Show All" etc etc.
> I want to remove this extra menu.
> Any idea?
Re: Remove Mac Specific Menu in RCP application [message #899137 is a reply to message #899136] Mon, 30 July 2012 16:14 Go to previous message
Valerio Santinelli is currently offline Valerio SantinelliFriend
Member
As Thomas said, that's part of the OS and it cannot be removed. It's not just Java or Eclipse that can't get rid of it.
Previous Topic:3.x RCP application running under 4.2 problem with medialib
Next Topic:Help with ITreePathContentProvider and ItreePathLabelProvider.
Current Time: Thu Feb 22 15:07:11 GMT 2018
Powered by FUDForum. Page generated in 0.03444 seconds
