Home » Modeling » TMF (Xtext) » Editor Plugin fails to start(Help on diagnosis)
Editor Plugin fails to start [message #897361] Mon, 23 July 2012 14:33 Go to next message
Michael A. is currently offline Michael A.
Hello
I could use some help with diagnosing why my editor/language-plugins fail to start after deployment. I've developed three xtext languages A, B, C and an ecore-model plugin D, with all languages importing D and B importing A. These languages/editors work just fine when started from the development environment.
I've exported all laguage- and ui-plugins and installed them into the dropins directory (dropins(<name>/eclipse/plugins/<jars>) of a fresh eclipse (4.2) with xtext (2.3)installed.
Now everything seems to work just fine except of the language/editor-plugin for language A. I do see all my plugins also the ones for language A in Help/About/Installationdetails/plugins. And there is an entry in the error log on a Guice error - CreationException : No implementation for org.eclipse.ui.IWorkbench was bound ... plus some others(XtendActivator - Failed to create injector for org.eclipse.xtend.core.Xtend, java.lang.NullPointerException at ... XtendExecutableExtensionFactory.java:21), but I guess the Guice-error is the cause of the others.
Anyone who can instantly tell what the problem might be? Wink
How would you diagnose/resolve the problem?
thanks, Micha
Re: Editor Plugin fails to start [message #897435 is a reply to message #897361] Tue, 24 July 2012 03:07 Go to previous messageGo to next message
Dennis Huebner is currently offline Dennis Huebner
Hi Michael,
could you please paste the whole stack trace ?
Are you sure that all other (B,C,D) editor plugins are working fine?
Dennis.
+Dennis Hübner
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: Editor Plugin fails to start [message #1022051 is a reply to message #897435] Thu, 21 March 2013 03:50 Go to previous message
Abhijeet Srivastva is currently offline Abhijeet Srivastva
Stack trace are-
java.lang.RuntimeException: Failed to create injector for org.eclipse.xtend.core.Xtend
at org.eclipse.xtend.ide.internal.XtendActivator.createInjector(XtendActivator.java:71)
at org.eclipse.xtend.ide.internal.XtendActivator.getInjector(XtendActivator.java:55)
at org.eclipse.xtend.ide.XtendExecutableExtensionFactory.getInjector(XtendExecutableExtensionFactory.java:26)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:49)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:260)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManager.java:875)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:609)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: com.google.inject.CreationException: Guice creation errors:
1) No implementation for javax.inject.Provider<org.eclipse.xtend.core.macro.TransformationContextImpl> was bound.
while locating javax.inject.Provider<org.eclipse.xtend.core.macro.TransformationContextImpl>
for field at org.eclipse.xtend.core.macro.AnnotationProcessor.modifyContextProvider(Unknown Source)
while locating org.eclipse.xtend.core.macro.AnnotationProcessor
for field at org.eclipse.xtend.core.jvmmodel.XtendJvmModelInferrer.annotationProcessor(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
2) No implementation for javax.inject.Provider<org.eclipse.xtend.core.macro.RegisterGlobalsContextImpl> was bound.
while locating javax.inject.Provider<org.eclipse.xtend.core.macro.RegisterGlobalsContextImpl>
for field at org.eclipse.xtend.core.macro.AnnotationProcessor.registerGlobalsContextProvider(Unknown Source)
2 errors
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:154)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at org.eclipse.xtend.ide.internal.XtendActivator.createInjector(XtendActivator.java:67)
... 83 more
Previous Topic:QualifiedNameProvider-Question
Next Topic:Unit test runner: Incompatible types
Current Time: Wed May 22 20:34:26 EDT 2013
Powered by FUDForum. Page generated in 0.02176 seconds
