Home » Modeling » EMF » Problem accessing resources in other depending projects
Problem accessing resources in other depending projects [message #897280] Mon, 23 July 2012 13:39 Go to next message
Franco Giustetto is currently offline Franco GiustettoFriend
Hello, I'm faced with an access problem of resources located in a project different from the main project.
I working on Eclipse Helios.
I have a project called Absweb that is (as the name suggest) a JAX-WS Web project build over ZK framework.
This project use controller beans taken from another project (ABSBL where BL stay for Business logic) where I can found the cache initialization file "cache.ccf"
again the ABSBL project use POJO from the ABSDB project (where DB stay for DataBase) where I can found the SqlConfig.XML files which contains definition for MyBatis framework.
ABSBL and ABSDB are both Java Projects.
When i build the various projects I get, among others, these warnings....
Classpath entry /ABSBL will not be exported or published. Runtime ClassNotFoundExceptions may result.
Classpath entry /ABSBL/bin/cache.ccf will not be exported or published. Runtime ClassNotFoundExceptions may result.
Classpath entry /ABSDB will not be exported or published. Runtime ClassNotFoundExceptions may result.
Classpath entry /ABSDB/src/SqlMapConfig.xml will not be exported or published. Runtime ClassNotFoundExceptions may result.
all throne by Classpath Dependency Validator Message
This is strange because I try both check and uncheck the "export" flag in the "Order and export" properties page without any substantial changes.
These are warnings, so I could also ignore it, but...
As soon I start the web application and the Spring container try to instantiate one of the ABSBL that contain the following line:
cache = JCS.getInstance("runValueCache");
I get an exception that tell me that the cache.ccf file cannot be found.
here a sample stack trace ( please tell me if you need complete stack trace or any other config file)
java.lang.IllegalStateException: Failed to load properties for name [/cache.ccf]
at org.apache.jcs.engine.control.CompositeCacheManager.configure(CompositeCacheManager.java:242)
at org.apache.jcs.engine.control.CompositeCacheManager.configure(CompositeCacheManager.java:194)
at org.apache.jcs.engine.control.CompositeCacheManager.getInstance(CompositeCacheManager.java:122)
at org.apache.jcs.JCS.ensureCacheManager(JCS.java:96)
at org.apache.jcs.JCS.getInstance(JCS.java:64)
...more
and if I exclude avoid instatiatingthis class by removing it from Spring's Application context I get errors as soon I instatiate a class that require the SqlMapConfig.xml exported by the ABSDB Jar file...
That is: it seems that I cannot see any resource exported from my projects or better, it seems I cannot export any resuouces from my projects.
this problem drive me crazy because I think I try every possible declaration combination without any appreciable result
could anybody help me?
Tahnk you
Franco
Re: Problem accessing resources in other depending projects [message #897289 is a reply to message #897280] Mon, 23 July 2012 13:54 Go to previous messageGo to next message
Franco,
Did you mean to post this on the EMF newsgroup/forum? It looks like it
belongs somewhere else, perhaps the Web Tools newsgroup/forum...
> changes.
> [/cache.ccf]
> at
> at
> at
> ..more
> projects.
> Tahnk you
> Franco
Re: Problem accessing resources in other depending projects [message #897299 is a reply to message #897289] Mon, 23 July 2012 14:17 Go to previous message
oops! Embarrassed I am definitely a newbie! I will post it in Web Tools newsgroup/forum
Previous Topic:[xcore] Code Snippet ignored with derived and refers references
Next Topic:EMF/XSD invalid xml
Current Time: Sun May 27 19:45:07 GMT 2018
Powered by FUDForum. Page generated in 0.02182 seconds
