Home » Newcomers » Newcomers » Can't add a library to my build path.(Can't write to .classpath)
Can't add a library to my build path. [message #897069] Sat, 21 July 2012 12:31 Go to next message
Calvin Cutts is currently offline Calvin CuttsFriend
Hi, I am running into an error when I try to add commons-io-2.4.jar to my build path. I right click on the file (in the package explorer) and click on add to build path, but it says it can't write to the .classpath file.
Does anyone have any ideas what's wrong?
Astralogic
Re: Can't add a library to my build path. [message #897092 is a reply to message #897069] Sat, 21 July 2012 16:41 Go to previous messageGo to next message
Javin Paul is currently offline Javin PaulFriend
Member
Does your .classpath is used by another process may be a hung file editor. I suggest try closing everything including eclipse and than relaunch it and than try adding JARs on build path.
Re: Can't add a library to my build path. [message #898359 is a reply to message #897092] Thu, 26 July 2012 09:21 Go to previous messageGo to next message
The file was set to be hidden, that's why it didn't work.
Astralogic
Re: Can't add a library to my build path. [message #898906 is a reply to message #898359] Sun, 29 July 2012 03:52 Go to previous message
Member
Thanks Astralogic, that is something good to know.
Previous Topic:Eclipse on a Tablet
Next Topic:OSGi and Spring Web MVC
Current Time: Sun Jun 24 03:47:47 GMT 2018
Powered by FUDForum. Page generated in 0.03107 seconds
