Home » Eclipse Projects » Eclipse Platform » Disable curved corners in Juno [solved]
Disable curved corners in Juno [solved] [message #896251] Tue, 17 July 2012 17:28 Go to next message
Ivan V is currently offline Ivan VFriend
After the upgrade from Indigo to Juno, windows have curved corners. How can disable this?
[Updated on: Wed, 18 July 2012 08:59]
Report message to a moderator
Re: Disable curved corners in Juno [message #896258 is a reply to message #896251] Tue, 17 July 2012 18:50 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You need to set the Preference>General>Appearance pref page to the classic theme, and then edit the CSS to Switch the Tab Style. http://wiki.eclipse.org/Eclipse4/CSS#Switching_tab_styles
PW
Re: Disable curved corners in Juno [message #896387 is a reply to message #896258] Wed, 18 July 2012 08:58 Go to previous message
Thank you. It worked.
Previous Topic:eclipse headless junit test framework
Next Topic:Disable Multiselection option is not available
Current Time: Fri Feb 23 15:07:19 GMT 2018
Powered by FUDForum. Page generated in 0.01570 seconds
