Home » Archived » Eclipse Process Manager (Stardust) » Sources eclipse setup(maven repo is not under M2_REPO)
Sources eclipse setup [message #895708] Sun, 15 July 2012 08:39 Go to next message
Florian Kammermann is currently offline Florian KammermannFriend
Hey together, I try to build from the sources and watch them with eclipse.
When I try to generate the eclipse files, with the following command:
mvn eclipse:eclipse
Then I can't, cause the pom.xml is from the packaging type:
<packaging>pom</packaging>
The module I tried with is stardust-engine-base.
Re: Sources eclipse setup [message #895712 is a reply to message #895708] Sun, 15 July 2012 08:49 Go to previous messageGo to next message
In the .classpath file which comes with the sources is the variable Q-ARCHIVE/thirdparty set.
What is the meaning of this? should this point to the maven repo?
Re: Sources eclipse setup [message #895843 is a reply to message #895712] Mon, 16 July 2012 09:38 Go to previous messageGo to next message
Shyam Prakash is currently offline Shyam PrakashFriend
Looks like Q-ARCHIVE points to local path. I see the some entries in
reporting.app.web\org.eclipse.stardust.reporting.app.web\deploy\tomcat\build-tomcat-5_5.xml and reporting.app.web\org.eclipse.stardust.reporting.app.web\deploy\tomcat\build.xml
Probably needs some cleaning of files.
~Shyam
Re: Sources eclipse setup [message #898711 is a reply to message #895843] Fri, 27 July 2012 10:06 Go to previous message
Robert Emsbach is currently offline Robert EmsbachFriend
That is correct. There should be no Q-Archive references in Stardust.
We will clean this up.
Rob
Previous Topic:Eclipse configurations
Next Topic:User not found error while running reports in Stardust env
Current Time: Sat Jan 20 01:36:37 GMT 2018
Powered by FUDForum. Page generated in 0.01304 seconds
