Home » Modeling » Papyrus » Problem with applied profiles
Problem with applied profiles [message #895058] Wed, 11 July 2012 14:54 Go to next message
Stefan Kuehnlein is currently offline Stefan KuehnleinFriend
Hallo everybody
I have some problems in using a registered profile.
I have done following steps:
1. Creating a Plugin-Project
2. Creating a new profile in the folder Profile
3. Defining some stereotypes
4. Defining the extention points
<extension
point="org.eclipse.gmf.runtime.emf.core.Pathmaps">
<pathmap
name="RGF_Profiles"
path="Profile">
</pathmap>
</extension>
<extension
point="org.eclipse.papyrus.uml.extensionpoints.UMLProfile">
<profile
name="Entity_Profiles"
path="pathmap://RGF_Profiles/entity.profile.uml"
qualifiednames="Entity_Profiles">
</profile>
</extension>
5. Exporting the plugin and restarting eclipse
6. Opening the new UML-model and try to apply the registered profile
The dialog for selecting an applied profile from the papyrus repository shows the new registered profile. After selecting the registered profile the dialog ends and nothing else happens. I cannot choose any profiles and I cannot apply a stereotype to any uml-elements.
The EMFTree shows the applied profile but no childs has been display.
Have someone any idea what is wrong?
Stefan
Re: Problem with applied profiles [message #960181 is a reply to message #895058] Sat, 27 October 2012 08:43 Go to previous messageGo to next message
Gunter Schranz is currently offline Gunter SchranzFriend
I have the same problem. Any clue why that happens?
Re: Problem with applied profiles [message #960240 is a reply to message #960181] Sat, 27 October 2012 09:45 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
Have you checked the error log? It might give a clue as to why
processing short-circuited.
Have you opened the UML model with the UML Model Editor and validated it?
Ed Willink
On 27/10/2012 10:43, Gunter Schranz wrote:
> Hello,
Re: Problem with applied profiles [message #961882 is a reply to message #960240] Sun, 28 October 2012 17:33 Go to previous messageGo to next message
I've found the problem:
I set the wrong target at the org.eclipse.emf.ecore.uri_mapping extension.
The problem was that I couldn't see any error when I tried to load the profile.
Thanks...
Re: Problem with applied profiles [message #961955 is a reply to message #961882] Sun, 28 October 2012 18:55 Go to previous message
Sounds like a bug. Please raise a Bugzilla.
Ed Willink
> extension.
> profile.
> Thanks...
Previous Topic:How to define a stereotype which subsets a meta-class association / redefine an attribute
Next Topic:how to create a sequence diagram with time modeling
Current Time: Wed May 23 15:12:21 GMT 2018
Powered by FUDForum. Page generated in 0.02279 seconds
