Home » Newcomers » Newcomers » Restarting Juno
Restarting Juno [message #894938] Wed, 11 July 2012 03:53 Go to next message
Werner Hövelmanns is currently offline Werner Hövelmanns
I have downloaded a New Version of eclipse and it worked all fine.
Now I have Problems to load an existing workspace either an new one.
I get the following messages, and i stuck.
!SESSION 2012-07-11 07:40:17.696 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-07-11 07:40:23.681
!MESSAGE Unable to load resource platform:/plugin/org.eclipse.platform/LegacyIDE.e4xmi
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'xmi' not found. (platform:/plugin/org.eclipse.platform/LegacyIDE.e4xmi, 2, 752)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadResource(ResourceHandler.java:234)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:205)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:366)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:220)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:554)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'xmi' not found. (platform:/plugin/org.eclipse.platform/LegacyIDE.e4xmi, 2, 752)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeature(XMLHandler.java:1985)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeature(XMLHandler.java:1949)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.handleUnknownFeature(XMIHandler.java:145)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2703)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:74)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2187)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1324)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1462)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1013)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:995)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:706)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.impl.dtd.XMLDTDValidator.startElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentScannerImpl$ContentDispatcher.scanRootElementHook(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.DTDConfiguration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 22 more
!ENTRY org.eclipse.osgi 4 0 2012-07-11 07:40:23.899
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:206)
Could anyone help me?
Re: Restarting Juno [message #895118 is a reply to message #894938] Wed, 11 July 2012 14:09 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
Try deleting <workspace>/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi with eclipse closed, and then start it up on that workspace again. Does that help?
PW
Re: Restarting Juno [message #896992 is a reply to message #895118] Fri, 20 July 2012 13:45 Go to previous messageGo to next message
Michael Harris is currently offline Michael Harris
This has happened for me too and I can't get it to go away. I've tried deleting all eclipse files and reinstalling but the message still persists.
!MESSAGE Unable to load resource platform:/plugin/org.eclipse.ui.workbench/LegacyIDE.e4xmi
I deleted .metadata folder: same error
I created a new workspace folder: same error.
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
Re: Restarting Juno [message #904428 is a reply to message #894938] Tue, 28 August 2012 08:14 Go to previous messageGo to next message
Klara Ward is currently offline Klara Ward
I have the same problem, did you find a solution?
java.version=1.7.0
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data D:\workspaces\mcmain/../jrmc_eclipse -dev file:D:/workspaces/mcmain/.metadata/.plugins/org.eclipse.pde.core/JRMC Eclipse Win x86_64/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
Re: Restarting Juno [message #911219 is a reply to message #904428] Tue, 11 September 2012 03:44 Go to previous messageGo to next message
Frustratingly, no I did not.
I had to roll back to Indigo. I can only assume that there is a solution, although I had so many other issues at the same time that I could not distinguish between them. This was a complete re-installation of environment for me. I must stress though, that I do not believe that this was solely an Indigo problem when I came across it.
Excuse the late reply. Have you found a solution over the last week?
Re: Restarting Juno [message #926197 is a reply to message #911219] Fri, 28 September 2012 07:55 Go to previous message
I believe I added org.eclipse.platform to my launch configuration,
not sure it's the correct way, but it worked for me.
Previous Topic:Eclipse Startup Error: Processing Java changes since last activation
Next Topic:Workbench could not be found in the registry
Current Time: Wed May 22 21:08:27 EDT 2013
Powered by FUDForum. Page generated in 0.01588 seconds
