Home » Newcomers » Newcomers » Failed to load JNI(jvm.dll)
Failed to load JNI [message #894571] Mon, 09 July 2012 16:02 Go to next message
Eudald Puig is currently offline Eudald PuigFriend
I've downloded demo version of eclipse "all in one" and intall it.
My computer has the last upgrade version of windows 7, and i also intalled last version Java JDK and JDR
My computre is 64 bits and I've installed "eclipse-reporting-juno-win32-x86_64"
Every thing seems work properely but at satarting the program it do not start because "Failed to load the JNI shared library" jvm.dll
What I'm doing wrong
Thanks to every body
icon7.gif  Re: Failed to load JNI [message #897413 is a reply to message #894571] Tue, 24 July 2012 04:11 Go to previous messageGo to next message
Erin McCall is currently offline Erin McCallFriend
Try installing the 32-bit version. I was getting the same error message every time I tried to start Eclipse, and this fix worked for me. I, too, am running fully-updated Windows 7 and had Java 7 already installed. Even though my machine is 64-bit, the version of Java I have is apparently 32-bit. If you have 32-bit Java, you have to use 32-bit Eclipse.
I suppose you could upgrade Java to 64-bit instead, but I'm not willing to try that now that I finally have Eclipse running!!
Re: Failed to load JNI [message #897416 is a reply to message #897413] Tue, 24 July 2012 04:46 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Also, there's no "demo" version. It's Open Source.
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:Error?
Next Topic:zxing
Current Time: Sat Mar 24 12:25:40 GMT 2018
Powered by FUDForum. Page generated in 0.03484 seconds
