Home » Eclipse Projects » GEF » GEF update site not available
GEF update site not available [message #894398] Mon, 09 July 2012 06:21 Go to next message
Sarkadi Csaba is currently offline Sarkadi CsabaFriend
Hi everyone,
I'm trying to install some eclipse plugins for my IBM Domino Designer (full eclipse based IDE). I'm following the directions of Niklas Heidloff "Setting up Source Control for NSFs and XPages in Domino 8.5.3" article.
I've succesfully managed to install GEF SDK 3.6.2 from the following repository:
http://download.eclipse.org/tools/gef/updates-pre-3_8/releases/
However, when I try to install the two svn plugins required (http://www.eclipse.org/downloads/download.php?file=/technology/subversive/0.7/builds/Subversive-incubation-0.7.9.I20100512-1900.zip and Subversive-connectors-2.2.2.I20100512-1900.zip ) I get the following errors:
CWPPR0031W: The requested provisioning operation(s) completed with partial success.
Network connection problems encountered during search.
Unable to access "http://download.eclipse.org/tools/gef/updates/releases/site.xml".
Unable to access site: "http://download.eclipse.org/tools/gef/updates/releases/site.xml" [Server returned HTTP response code: "404 Not Found" for URL: http://download.eclipse.org/tools/gef/updates/releases/site.xml.]
And also, the real GEF update site appears, that is undeletable from the update site list.
I have emailed the webmaster, and got back the following response:
It would appear that GEF has transitioned to the newer Eclipse p2
installer and as such has archived their older update site
So currently I don't know how to proceed. I have checked the eclipse directories, and found out that a numerous files contain the string "http://download.eclipse.org/tools/gef/updates/releases/site.xml" . So should I replace all these string with the old update site url?
Thanks for your help!
Re: GEF update site not available [message #1027272 is a reply to message #894398] Tue, 26 March 2013 19:51 Go to previous messageGo to next message
jim roysdon is currently offline jim roysdonFriend
Did you ever get an answer to this? I have been spinning my wheels for a while now. I ran into the same issues. I've also tried the OpenNTF solution and may have to try something else.
Re: GEF update site not available [message #1695626 is a reply to message #1027272] Mon, 18 May 2015 08:27 Go to previous message
Noga Rotman is currently offline Noga RotmanFriend
For those who are having the same problem: just use the same link without the "site.xml" at the end; that is:
Previous Topic:[ZEST] Center view on a selected node
Next Topic:Weird Node Resizing Problem
Current Time: Tue Apr 24 21:24:20 GMT 2018
Powered by FUDForum. Page generated in 0.01939 seconds
