| Compile Papyrus [message #894348] |
Sun, 08 July 2012 10:53  |
Kenia Santos Messages: 4 Registered: July 2012 |
Junior Member |
I need to compile Papyrus but I dont have much experience so I need help.
I would like to receive a step by step how to compile the code.
The source code must be imported what kind of project?
I need to insert some diagrams in SysML. This is very important work for me.
Please help me.
Best regards
Kênia
| Re: Compile Papyrus [message #894437 is a reply to message #894348] |
Mon, 09 July 2012 05:06   |
Camille Letavernier Messages: 225 Registered: February 2011 |
Hello Kênia,
First of all, you will need to install all the Papyrus Dependencies:
- EMF
- GMF
- EMF Facet
- MoDisco
- QVTo
- X-Text
(You can also install Papyrus ; it will automatically install all the required dependencies)
Then, you should check out the sources from the Papyrus repository, using this Project Set File:
http://download.eclipse.org/modeling/mdt/papyrus/psf/subclipse/trunk/plugins_http.psf (From http://wiki.eclipse.org/Papyrus_Developer_Guide#Retrieve_code)
This psf file is generated automatically from the Papyrus SVN Repository ; it contains a few plug-ins which are actually not included in the Papyrus distribution (And which may not compile). I won't list all the plug-ins which should or should not compile correctly, but here are a few tips:
- Errors on *.qvto, *.uiCustom, *.facet, *.querySet files are not a problem.
- Developer plug-ins (From the "developer" working set) are included in the *.psf file, but are not required. They may or may not compile, depending on what you've installed.
- The following plug-ins are not included in the Papyrus distribution, and may not compile. You can simply close them:
- {oep}.views.documentation.*
- {oep}.uml.documentation
- {oep}.uml.properties.tabbedproperties.comments
- {oep}.customization
Papyrus is supposed to compile on Eclipse 4.2 ; a few plug-ins won't compile on Eclipse 3.8.
If you still meet some errors, tell me which plug-ins are affected and the kind of error you meet.
Camille
| Re: Compile Papyrus [message #894784 is a reply to message #894781] |
Tue, 10 July 2012 10:11   |
Hello Kênia,
The psf (Project Set File) is a helper to download a set of projects from a team repository.
Due to the hierarchy of the Papyrus SVN Repository, it can be complicated to checkout the sources manually. So, you should use the PSF file. To use the psf file, in Eclipse, use Import > Team > Team Project Set, and use the psf URL (http://download.eclipse.org/modeling/mdt/papyrus/psf/subclipse/trunk/plugins_http.psf)
It will checkout all Papyrus plug-ins from the SVN repository, and store them in Eclipse Working Sets. That's the simplest way to checkout the Papyrus sources.
Of course, if you've already checkout the sources manually, you don't need to use the PSF. That's just an alternative way.
Camille
| Re: Compile Papyrus [message #902698 is a reply to message #894437] |
Sun, 19 August 2012 16:54   |
ibrahim beicker Messages: 1 Registered: August 2012 |
Junior Member |
Camille Letavernier wrote on Mon, 09 July 2012 05:06Hello Kênia,
- EMF
- GMF
- EMF Facet
- MoDisco
- QVTo
- X-Text
Camille
Hello
I've installed all the dependencies and downloaded the code through the Project Set File, but there's one project with errors
the project org.eclipse.papyrus.sysml.diagram.parametric have the following dependencies missing
org.eclipse.papyrus.resource (0.9.0)
org.eclipse.papyrus.resource.edit (0.9.0)
org.eclipse.papyrus.parsers (0.9.0)
these folders are not present on the source, what should I do?
FUDForum. Page generated in 0.01933 seconds
