Home » Modeling » TMF (Xtext) » XMLBeautifier uses wrong line separator
XMLBeautifier uses wrong line separator [message #894043] Fri, 06 July 2012 09:27 Go to next message
Frank Felfe is currently offline Frank Felfe
Hello there,
I'm testing an upgrade from xtext 2.2. to xtext 2.3. and found a problem with the org.eclipse.xtend.typesystem.xsd.XMLBeautifier which in 2.3 inserts the string '
' in every line wrap.
Debugging revealed that the org.eclipse.xtend.typesystem.xsd.XMLMixedContentFormatter now uses the system property line.separator which is \n\r instead of \n which was hard coded in version 2.2.
Is there something I can do about it? I assume I cannot change the system property.
Greetings and Thanks
Frank
Re: XMLBeautifier uses wrong line separator [message #894060 is a reply to message #894043] Fri, 06 July 2012 10:07 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
What about setting the property explicitly (something like
-Dline.separator= or subclassing the beautifier and workflow? Btw
what is the problem with the windows line separator
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: XMLBeautifier uses wrong line separator [message #894061 is a reply to message #894060] Fri, 06 July 2012 10:09 Go to previous messageGo to next message
Sorry meant beautifier and workflow
Re: XMLBeautifier uses wrong line separator [message #894078 is a reply to message #894060] Fri, 06 July 2012 10:39 Go to previous message
The problem with the windows line separator is that the beautifier produces invalid xml files which cannot be parsed e.g. by spring. An example of the xml output is added below.
I don't understand why there are these extra characters. The beautifier seems to convert the \r to
 and outputs this instead of the control character.
One would expect the beautifier to works out of the box. To me it looks broken.
Here is an example of the beautifier output with wrong characters marked red:
<beans
xmlns:xsi="someSchemaLink" xmlns="someSchemaLink"
xsi:schemaLocation="someSchemaLink">&#xD;
<bean class="myBeanClass"
id="myBeanId"/>&#xD;
</beans>&#xD;
Previous Topic:IJvmModelInferrer and Generation of Java files outside of Eclipse model project
Next Topic:Why terminal do not generate content assist ?
Current Time: Fri May 24 19:41:12 EDT 2013
Powered by FUDForum. Page generated in 0.01718 seconds
