Home » Eclipse Projects » scout » Smart field with master
Smart field with master [message #893713] Thu, 05 July 2012 06:47 Go to next message
Bertin Kiekebosch is currently offline Bertin Kiekebosch
I have two smart fields. On the second field i did set the first one as a master. So in the GUI this looks good. But I cannot find out how to make the rest work. The second field never gives me any results any more. I guess I have to change the lookup call but cannot figure out how.
Re: Smart field with master [message #893731 is a reply to message #893713] Thu, 05 July 2012 07:42 Go to previous messageGo to next message
Andreas Hoegger is currently offline Andreas Hoegger
The following pseudocode block shows the two most common variants.
MasterField:
SlaveField:
  getConfiguredMasterField(){
    return MasterField.class;
  // variant 1 change the whole lookup call
  execChangedMasterValue(Object newValue){
    if(newValue.equals(value1)){
      setLookupCall(new LookupCall1());
    }else{
      setLookupCall(new LookupCall2());
  // variant 1 handle the variants in lookup calls.
    getLookupCall().setVariant(newValue);
Let me know your success;)
-andreas
Re: Smart field with master [message #893741 is a reply to message #893713] Thu, 05 July 2012 08:39 Go to previous messageGo to next message
Bruno  Köferli is currently offline Bruno Köferli
A - in my opinion - better way is to use the master property on LookupCall, which contains the value of the configured master field.
The following pseudoSQL block shows you a possible usage of this master property:
select value from slave_values where master_value = :master
See here for using LookupCall properties in SQL lookup service.
Re: Smart field with master [message #893752 is a reply to message #893741] Thu, 05 July 2012 09:03 Go to previous messageGo to next message
No succes yet:
Do I have to make any changes at the back-end. Until now I only have a getConfiguredSqlSelect in the LookupService
protected String getConfiguredSqlSelect() {
return "SELECT id, version " +
"FROM component_version " +
"<key> where id = :key</key> " +
"<text> where UPPER(name) LIKE CONCAT(UPPER(:text), '%')</text>";
I wonder how the master value gets in there?
In the shared section I have in my LookupCall
protected boolean getConfiguredMasterRequired() {
return true;
In the Client I do not have
because I cannot find this. I do have on the slave field:
protected void execChangedMasterValue(Object newMasterValue) throws ProcessingException {
getLookupCall().setMaster(newMasterValue);
And for the rest I have set the configured values masterRequired and MasterField on the slave field.
Re: Smart field with master [message #893817 is a reply to message #893713] Thu, 05 July 2012 10:48 Go to previous messageGo to next message
The SQL in your lookup service - I assume that it will be used by the configured LookupCall of your slave field - looks ok. (Here you can refer to your master value by using the binding ":master".)
getConfiguredMasterRequired() on LookupCall is not needed or should be better defined on the slave SmartField - I cannot tell you why this property exists on FormFields and on LookupCalls.
Additionally the execChangedMasterValue() on your slave field can be removed, because the master value will be set to LookupCall by Scout (see AbstractSmartField.prepareBrowseLookup(), prepareKeyLookup(), ...).
If your slave field still stays empty, you can set some breakpoints. F.e. on
  • ... AbstractSmartField.prepareBrowseLookup() to check the master value on the LookupCall
  • ... <your lookup service>.getConfiguredSqlSelect() to check if your SQL is being executed
Re: Smart field with master [message #893829 is a reply to message #893817] Thu, 05 July 2012 11:29 Go to previous message
Thanks, got it working
so in the end, I just had to set the master required and master field on the slave field and change my query in getConfiguredSqlSelect() in the LookupService where the important part is that I can use the :master as the bind value like
" where foreing_key_to_master_table = :master"
Previous Topic:File download from server
Next Topic:Correct way to create hotkeys
Current Time: Tue May 21 21:31:44 EDT 2013
Powered by FUDForum. Page generated in 0.02024 seconds
