Re: eclipse-jee-juno-win32-x86_64 closes unexpectedly after startup [message #893144 is a reply to message #892467] |
Mon, 02 July 2012 20:47 |
Birger Jarl Messages: 1 Registered: July 2012 |
Junior Member |
Hi James!
I'm experiencing the same problems as you.
Let me describe my problem:
I started out with Eclipse Indigo, developing in Java. I'm running this on Windows 7 64-bit.
When Juno hit the release, I updated to Juno through the repositories and used "Install new updates". It updated without errors. When I rebooted Eclipse, the problem started to occur. Eclipse initiates the startup, but closes after the loading the workspace, right about when it starts to build the IDE windows.
I've tried to change workspace, but the same problem still happens.
I've downloaded a fresh copy of Juno, no change.
I've uninstalled all Java components, downloaded them fresh from Oracle, installed and then tried again. Still not working.
I don't get any logfile in my workspace directory.
I'm starting Eclipse through the command prompt with -debug -consoleLog -clean. I do not get any errors nor indication that anything is wrong. It just unexpectedly closes after showing the Splash while building IDE windows, and then nothing else.
I've really tried everything that I've come up with. Nobody seem to have any idea whatsoever of what is causing the problem. It's even stranger that I don't get any log file in my workspace directory.
I'm unsure how to post this as a bug, so if someone would point out how, I'd gladly do it. I'm just happy there's at least one more person in the world having the same problem as I am having.
B
FUDForum. Page generated in 0.02866 seconds
