Home » Newcomers » Newcomers » How to upgrdae from Indigo to Juno?
How to upgrdae from Indigo to Juno? [message #892280] Wed, 27 June 2012 15:14 Go to next message
Chris Wa is currently offline Chris WaFriend
I'm currently running Eclipse Indigo and now want to upgrade to Juno with the "Check for Updates" option.
I've added the repository
http: // download.eclipse.org/ releases/ juno
to my available software sites.
But I've ran Check for Updates several times and didn't get the new version.
I allways get the message "No updates were found"
How can I update automatically?
Re: How to upgrdae from Indigo to Juno? [message #892570 is a reply to message #892280] Thu, 28 June 2012 16:04 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
It depends on what you have installed that you would like to update. Eclipse classic SDK? Any other bundles installed?
By default, eclipse won't update from 3.7.x to 4.2 (that's disallowed). In theory if you have the Eclipse classic SDK you could point to releases/juno (or eclipse/updates/4.2) and ask P2 to install the 4.2 SDK deliberately. But I haven't tested the outcome myself.
PW
Re: How to upgrdae from Indigo to Juno? [message #892620 is a reply to message #892570] Thu, 28 June 2012 18:26 Go to previous messageGo to next message
Denis Roy is currently offline Denis RoyFriend
Your best bet is to likely do a clean install and point your Juno install to your existing workspace.
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
Re: How to upgrdae from Indigo to Juno? [message #892792 is a reply to message #892620] Fri, 29 June 2012 17:26 Go to previous messageGo to next message
Ken Creppin is currently offline Ken CreppinFriend
I unzipped Juno to the Indigo directory, pointed to my current workspace, then ran update and all seems to work fine so far. Was I lucky, lol?
Re: How to upgrdae from Indigo to Juno? [message #892950 is a reply to message #892280] Mon, 02 July 2012 06:48 Go to previous messageGo to next message
Andreas Mueller is currently offline Andreas MuellerFriend
The suggested way is to
1. Install the new version of Eclipse in a new location, separate from any old version of Eclipse.
and set the workspace (quote: "Tip: It doesn't hurt to make a backup of your workspace before upgrading.") to the old location, either on first startup or using the -data command line argument
(see: Upgrading Eclipse; sorry, this £!èç%&ç* system does not allow to insert clickable links even within eclipse.org: "You cannot use links until you have posted more than 25 messages.")
Re: How to upgrdae from Indigo to Juno? [message #893276 is a reply to message #892950] Tue, 03 July 2012 12:54 Go to previous message
Andreas Mueller wrote on Mon, 02 July 2012 02:48
I'm working on fixing that.
Denis Roy
Previous Topic:j2me error
Next Topic:unable to start jboss server eclipsce in debug mode
Current Time: Sun May 27 10:10:35 GMT 2018
Powered by FUDForum. Page generated in 0.02872 seconds
