Home » Eclipse Projects » BIRT » bigint problem
bigint problem [message #891846] Tue, 26 June 2012 09:27 Go to next message
smith link is currently offline smith linkFriend
birt 2.3.x
Database data type is bigint, birt data type is Decimal, There are some code in org.eclipse.birt.report.data.oda.jdbc_2.3.1.v20080827/plugin.xml
<dataTypeMapping
               nativeDataType="BIGINT"
               nativeDataTypeCode="-5"
               odaScalarDataType="Decimal"/>
sometimes I get a negative number at the cross table summary fields .
for example>>>>
SQL result: 130265097291150
birt result: -1260796530
[Updated on: Tue, 26 June 2012 09:38]
Report message to a moderator
Re: bigint problem [message #892042 is a reply to message #891846] Wed, 27 June 2012 00:28 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Do you get this issue when use just a table or is it only in the crosstab?
Jason
On 6/26/2012 5:27 AM, smith link wrote:
> birt 2.3.x
> <dataTypeMapping
> sometimes I get a negative number at report.
Re: bigint problem [message #892052 is a reply to message #892042] Wed, 27 June 2012 01:40 Go to previous messageGo to next message
Re: bigint problem [message #892055 is a reply to message #892042] Wed, 27 June 2012 02:01 Go to previous message
I'm very sorry, it's my fault! Both summary fields and binding data fields need to be Decimal. Very Happy
Thanks Jason.
Jason Weathersby wrote on Tue, 26 June 2012 20:28
Jason
> birt 2.3.x
> <dataTypeMapping
Previous Topic:How to override the function for the "Finish" button on a Data Source Wizard Page?
Next Topic:Adobe live cycle & POI comparison
Current Time: Fri May 25 05:31:22 GMT 2018
Powered by FUDForum. Page generated in 0.01749 seconds
