Home » Modeling » ATL » Problem MyRules.asm does not exist
Problem MyRules.asm does not exist [message #891620] Mon, 25 June 2012 11:19 Go to next message
dorraaaa Z is currently offline dorraaaa ZFriend
i have specify my rules in file MyRules.atl
But, when i do run configuration in my atl project ,a message appears in the console : File MyRules.asm does not exist
Can you tell me what can i do ??
thanks
Re: Problem MyRules.asm does not exist [message #1047442 is a reply to message #891620] Tue, 23 April 2013 07:56 Go to previous messageGo to next message
Basma Moukhtar is currently offline Basma MoukhtarFriend
I have the same problem, although my file doesn't contain any syntax error.
Can anyone help, please?
Basma Moukhtar.
Re: Problem MyRules.asm does not exist [message #1047445 is a reply to message #891620] Tue, 23 April 2013 08:01 Go to previous messageGo to next message
Gunnar Arndt is currently offline Gunnar ArndtFriend
Member
ASM is the assembler file, i.e. the compilate of your ATL source file. Sound like it isn't compiled. Does your project have the 'ATL nature' (purple and yellow dot on the folder symbol of Eclipse's resource tree)?
Re: Problem MyRules.asm does not exist [message #1050082 is a reply to message #1047445] Fri, 26 April 2013 17:16 Go to previous messageGo to next message
Yes, it is.
And the atl file also has the same shape.
Re: Problem MyRules.asm does not exist [message #1053442 is a reply to message #1050082] Sun, 05 May 2013 22:40 Go to previous message
The problem is solved by reinstalling the atl.
Previous Topic:Learning ATL, can't run the tutorial
Next Topic:convertion from string to BigDecimal
Current Time: Fri Apr 27 01:03:15 GMT 2018
Powered by FUDForum. Page generated in 0.01672 seconds
