Home » Eclipse Projects » EclipseLink » Maven Test Fails with Custom Logger(Testing EclipseLink in Maven)
Maven Test Fails with Custom Logger [message #890737] Fri, 22 June 2012 23:52
Rick O\\\'Shea is currently offline Rick O\\\'SheaFriend
This may be a maven:surefire issue but under no circumstances will tests succeed with EclipseLink when using a custom logger. Adding a custom logger is simple:
(excuse the x, but you cannot post links until you have 25 messages)
httpx://whileitcompiles.com/programming/java/enabling-slf4j-logging-in-eclipselink/
Unfortunately, maven tests will always fail claiming they cannot find the class. The class is part of the library under test, so it's included in the classpath of a test.
Adding the jar as an "additional classpath" entry fails, too:
httpx://maven.apache.org/plugins/maven-surefire-plugin/examples/configuring-classpath.html
Finally, even creating a maven repository and including that in your pom.xml fails.
httpx://blog.dub.podval.org/2010/01/maven-in-project-repository.html
I would really like to have one logger for JPA and the application itself.
Previous Topic:No Persistence provider
Next Topic:[SOLVED] Entity Class identity problem in OSGi after uninstalling/reinstalling persistence bundle
Current Time: Fri Jan 19 09:50:16 GMT 2018
Powered by FUDForum. Page generated in 0.01678 seconds
