Home » Newcomers » Newcomers » No output in eclipse console
No output in eclipse console [message #890216] Thu, 21 June 2012 13:35 Go to next message
julius wetzk is currently offline julius wetzkFriend
i installed the latest version of eclipse on my computer and used a little bit of java code.
No errors displayed. The only problem is when i press the run button there is no output in the eclipse console. "Allocate console" is activated.
I successfully compiled my .java-file with the cmd and got it to run with java. Everything works perfect but not in eclipse.
Does anybody know an answer?
Re: No output in eclipse console [message #890217 is a reply to message #890216] Thu, 21 June 2012 13:42 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
On 21.06.2012 15:35, julius wetzk wrote:
Make sure that you create a Java project and that your Java files are in
a source folder of that project.
Dani
> activated.
Re: No output in eclipse console [message #890224 is a reply to message #890217] Thu, 21 June 2012 14:04 Go to previous messageGo to next message
Hi Danny,
i use a java project and the java-file is in the src folder.
Any other solution?
Re: No output in eclipse console [message #890229 is a reply to message #890224] Thu, 21 June 2012 14:16 Go to previous messageGo to next message
On 21.06.2012 16:04, julius wetzk wrote:
> Hi Danny,
> Any other solution?
You don't have auto-build on and forgot to build?
Dani
Re: No output in eclipse console [message #890230 is a reply to message #890229] Thu, 21 June 2012 14:20 Go to previous messageGo to next message
Dont know what you mean by auto-build. Is this a function in eclipse?
Sorry, but im totally new to this.
Re: No output in eclipse console [message #890233 is a reply to message #890230] Thu, 21 June 2012 14:23 Go to previous messageGo to next message
Help > Welcome. Then go through the 'Create a Hello World application'
tutorial
Dani
Re: No output in eclipse console [message #890237 is a reply to message #890233] Thu, 21 June 2012 14:41 Go to previous messageGo to next message
I did the tutorial but that didnt help.
As i said i got it running with the command line so my java code is correct.
The function "build automatically" was and is activated.
I changed nothing in eclipse. Is there any other thing i can do? I really need this to work.
Re: No output in eclipse console [message #890239 is a reply to message #890237] Thu, 21 June 2012 14:52 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> correct.
What happens when you drill down to your .java file in the Project or
Package Explorer view, right-click it, and choose Run As -> Java
Application?
Re: No output in eclipse console [message #890242 is a reply to message #890239] Thu, 21 June 2012 15:06 Go to previous messageGo to next message
when i run the .java-file as java application eclipse shows the console view but it is empty.
all the same.
Re: No output in eclipse console [message #892180 is a reply to message #890216] Wed, 27 June 2012 10:19 Go to previous message
Marcel Baalbaki is currently offline Marcel BaalbakiFriend
Same problem over here.
Followed the tutorial, didnt throw errors.
I don't know which step was implicit in the tutorial.
Previous Topic:Oracle WLS fails to start with proxy enabled
Next Topic:Juno release to general public
Current Time: Thu Jun 21 18:34:00 GMT 2018
Powered by FUDForum. Page generated in 0.03444 seconds
