Home » Archived » Visual Editor (VE) » using jgoodies and swinglabs classes
using jgoodies and swinglabs classes [message #118338] Sun, 19 February 2006 19:40 Go to next message
Originally posted by: pierre.couvy.free.fr
Hi all,
Did anyone try to use VE and jgoodies and/or swinglabs classes ?
Re: using jgoodies and swinglabs classes [message #118347 is a reply to message #118338] Sun, 19 February 2006 20:27 Go to previous messageGo to next message
Pico a écrit :
> Hi all,
> Thanks :)
I do some searches on the net. The real question is maybe : what about
the "org.jdesktop.layout.GroupLayout" support in VE ?
I mean, i try to import some code from Netbeans. This code was designed
with matisse which use this layout.
When i open it in VE, Eclipse launches a remote JVM, starts to draw the
panel (my code) and crash (again ;-p). But i just can see that the
organisation of the panel is not good at all. All components are simply
presented from left to rigth.
Any ideas ?
Re: using jgoodies and swinglabs classes [message #118356 is a reply to message #118347] Sun, 19 February 2006 20:47 Go to previous messageGo to next message
Jeff Myers is currently offline Jeff MyersFriend
The VE does not provide any support for GroupLayout. Currently the VE
only supports the layouts included with Java (except SpringLayout), and
SWT (except FormLayout). There are enhancement requests open to support
SWT and JGoodies FormLayouts
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=77683) but it's unlikely
that the VE team will have time to address these anytime soon - so work
on these items will likely have to come from the Open Source Community.
If you'd like to support GroupLayout as well, a contribution of code
would be greatly welcomed :)
- Jeff
Pico wrote:
> Pico a écrit :
>> Hi all,
>> Thanks :)
> Any ideas ?
Re: using jgoodies and swinglabs classes [message #118577 is a reply to message #118356] Mon, 20 February 2006 07:29 Go to previous messageGo to next message
Why not... I think about it.
I had already done some small plugins too add those libraries
(swinglabs, groupbag layout and jgoodies) into the build path. you know
with the "Add library..." button. It works.
The next step should be to contribute into the palette.
But before going further, i try to see the behavior of VE with those
libraries. That's why i created my little project imported from
netbeans; I had all needed jars in my build path. I think there is a pb
with groupbag layout since components like JXTitledPanel, JXTreeTable
are well drawn but badly organised.
i'll try to isolate this evening. i'll replace layout with jfc ones.
thanks for you reply Jeff
> - Jeff
> Pico wrote:
>> Pico a écrit :
>>> Hi all,
>>> Thanks :)
>> designed with matisse which use this layout.
>> the panel (my code) and crash (again ;-p). But i just can see that the
>> simply presented from left to rigth.
>> Any ideas ?
Re: using jgoodies and swinglabs classes [message #118591 is a reply to message #118356] Mon, 20 February 2006 09:33 Go to previous message
--------------030008050306030003030801
I do some code manipulations :
i removed all grouplayouts (replace it by borderlayout or gridbaglayout),
that looks very important, or else the components are putted side by
side instead of being nested :/
so long grouplayout. I don't need it
i replaced numbers of "getContentPane().add()" by some basic "add()".
VE works fine with swinglabs components. I join a sreenshot (i use
Shadowborder, jxtitlepane, jxcollapsiblepane, jxtaskpane, jxtreetable,
etc...). All of that stuff works great. As those components are
JavaBeans, the properties view is well feed. Good news.
So here we are for now :)
If i do the ve extension. i would need to add the components into the
palette first. Then add some more specialized properties editors... Am i
rigth ?
that's sounds feasible.
Jeff Myers a
Re: using jgoodies and swinglabs classes [message #612150 is a reply to message #118338] Sun, 19 February 2006 20:27 Go to previous message
Pico a écrit :
> Hi all,
> Thanks :)
Any ideas ?
Re: using jgoodies and swinglabs classes [message #612151 is a reply to message #118347] Sun, 19 February 2006 20:47 Go to previous message
- Jeff
Pico wrote:
> Pico a écrit :
>> Hi all,
>> Thanks :)
> Any ideas ?
Re: using jgoodies and swinglabs classes [message #612152 is a reply to message #118356] Mon, 20 February 2006 07:29 Go to previous message
> - Jeff
> Pico wrote:
>> Pico a écrit :
>>> Hi all,
>>> Thanks :)
>> Any ideas ?
Re: using jgoodies and swinglabs classes [message #612153 is a reply to message #118356] Mon, 20 February 2006 09:33 Go to previous message
rigth ?
Jeff Myers a
Previous Topic:using jgoodies and swinglabs classes
Next Topic:changing color of AWT.label (1.2M1)
Current Time: Thu Apr 26 17:45:23 GMT 2018
Powered by FUDForum. Page generated in 0.03100 seconds
