Home » Modeling » EMF » [CDO] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl]
[CDO] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #885820] Wed, 13 June 2012 16:51 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
Trying to execute a simple query using this code
EClass cls= topology.eClass();
			String queryString = topology.eClass().getName().concat(".nodes->size()>50");
			System.out.println(queryString);
			CDOQuery query = topology.cdoView().createQuery("ocl", queryString, cls);
We've got the exception:
[ERROR] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl]
org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl]
	at org.eclipse.net4j.util.container.ManagedContainer.getFactory(ManagedContainer.java:193)
	at org.eclipse.net4j.util.container.ManagedContainer.createElement(ManagedContainer.java:492)
	at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:281)
	at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:265)
	at org.eclipse.emf.cdo.spi.server.ContainerQueryHandlerProvider.getQueryHandler(ContainerQueryHandlerProvider.java:42)
	at org.eclipse.emf.cdo.internal.server.Repository.getQueryHandler(Repository.java:909)
	at org.eclipse.emf.cdo.internal.server.QueryManager$QueryContext.run(QueryManager.java:292)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
	at java.lang.Thread.run(Thread.java:662)
could anyone tell me what should i do?
ocl and OCL is as query language name tested.
The running CDO server is Ok, we can create, store and retrieve objects from it.
We use CDO 4.0.1
Re: [CDO] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #885841 is a reply to message #885820] Wed, 13 June 2012 17:40 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
You just have to deploy the org.eclipse.emf.cdo.server.ocl bundle to your repository OSGi installation.
Cheers
/Eike
http://www.esc-net.de
Am 13.06.2012 18:51, schrieb Missing name Mising name:
> We use CDO 4.0.1
Re: [CDO] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #895090 is a reply to message #885841] Wed, 11 July 2012 16:33 Go to previous messageGo to next message
hadrien hadrien is currently offline hadrien hadrienFriend
exact same error trace as the 1st message of this post.
I am running the CDO server as a feature, CDOv4.0.0
I included "org.eclipse.emf.cdo.server.ocl" plugin to the server configuration, clean, start... still the same problem when executing:
CDOQuery cdoQuery = transaction.createQuery("ocl", "Book.allInstances()->select(book:Book | book.title = 'Eclipse Modeling Framework')");
Can you help me to figure out what i did miss ?
Re: [CDO] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #895101 is a reply to message #895090] Wed, 11 July 2012 16:59 Go to previous messageGo to next message
Am 11.07.2012 18:33, schrieb hadrien hadrien:
> when executing:
On the server's OSGi console please enter "ss" and see if the org.eclipse.emf.cdo.server.ocl bundle is resolved or
active. If not there may be a problem with the OCL dependencies.
Cheers
/Eike
Re: [CDO] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #895155 is a reply to message #895101] Wed, 11 July 2012 20:14 Go to previous messageGo to next message
Hey,
both plugins appear as "installed"... what would you suggest ?
(see console trace below)
Framework is launched.
id	State       Bundle
0	ACTIVE      org.eclipse.osgi_3.7.2.v20120110-1415
2	ACTIVE      org.eclipse.equinox.preferences_3.4.2.v20120111-2020
5	ACTIVE      org.eclipse.equinox.app_1.3.100.v20110321
8	ACTIVE      org.eclipse.emf.ecore_2.7.0.v20120127-1122
10	<<LAZY>>    org.eclipse.core.contenttype_3.4.100.v20110423-0524
11	ACTIVE      org.eclipse.emf.common_2.7.0.v20120127-1122
12	ACTIVE      org.eclipse.equinox.common_3.6.0.v20110523
13	ACTIVE      org.eclipse.core.runtime_3.7.0.v20110110
16	ACTIVE      org.eclipse.core.jobs_3.5.101.v20120113-1953
18	ACTIVE      org.eclipse.emf.ecore.change_2.7.1.v20120127-1122
19	RESOLVED    org.eclipse.core.runtime.compatibility.registry_3.5.0.v20110505
	            Master=22
20	ACTIVE      org.eclipse.emf.ecore.xmi_2.7.0.v20120127-1122
22	ACTIVE      org.eclipse.equinox.registry_3.5.101.R37x_v20110810-1611
	            Fragments=19
24	ACTIVE      org.eclipse.net4j.db_4.0.0.v20111221-2122
25	ACTIVE      org.eclipse.emf.cdo_4.0.1.v20120214-1021
26	ACTIVE      org.eclipse.net4j.util_3.1.1.v20111210-0952
27	ACTIVE      org.eclipse.emf.cdo.server_4.0.1.v20111208-1739
28	ACTIVE      org.eclipse.net4j.tcp_4.0.0.v20110607-1632
29	ACTIVE      org.eclipse.net4j_4.0.1.v20111123-0654
30	ACTIVE      org.eclipse.emf.cdo.server.net4j_4.0.1.v20120113-1233
31	ACTIVE      org.eclipse.emf.cdo.common_4.0.1.v20111215-1854
32	ACTIVE      org.eclipse.emf.cdo.server.db_4.0.1.v20111221-2220
35	RESOLVED    com.mysql.jdbc_5.1.11
36	ACTIVE      org.eclipse.net4j.db.mysql_4.0.1.v20110727-0844
37	INSTALLED   org.eclipse.emf.cdo.server.ocl_4.0.0.v20110818-0735
38	INSTALLED   org.eclipse.emf.query.ocl_2.0.0.v20091215-1624
Re: [CDO] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #895203 is a reply to message #895155] Thu, 12 July 2012 04:47 Go to previous messageGo to next message
Am 11.07.2012 22:14, schrieb hadrien hadrien:
> Hey,
"Installed" means "Not resolved", required bundles are missing.
In this case, as I already suspected, org.eclipse.ocl.ecore
Bundle-SymbolicName: org.eclipse.emf.cdo.server.ocl;singleton:=true
Require-Bundle: org.eclipse.core.runtime;bundle-version="[3.4.0,4.0.0)",
org.eclipse.ocl.ecore;bundle-version="[3.0.0,4.0.0)",
org.eclipse.emf.cdo.server;bundle-version="[4.0.0,5.0.0)"
I generally create Eclipse installations with the p2 director tool, which would have pointed this problem out earlier,
or given an adequate list of p2 repositories (see the bookmarks.xml files on our downloads page) fix it silently.
Cheers
/Eike
> id State Bundle
> Master=22
> Fragments=19
Re: [CDO] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #895204 is a reply to message #895155] Thu, 12 July 2012 04:49 Go to previous message
http://wiki.eclipse.org/Where_Is_My_Bundle may also help.
Cheers
/Eike
Previous Topic:EMF databinding and resource change
Next Topic:[Xbase] How to integrate xbase interpreter into another DSL interpreter?
Current Time: Mon Apr 23 15:47:49 GMT 2018
Powered by FUDForum. Page generated in 0.01939 seconds
