Home » Modeling » EMF » Override eSet()... Should I?
Override eSet()... Should I? [message #885782] Wed, 13 June 2012 15:28 Go to next message
Poissy B. is currently offline Poissy B.Friend
Member
Hi all EMFers!
Please bare with me since I'm new at EMF. I have a class that maintains two distinct collections of another class (1-many containment relationship). Here's a simplified example:
Class A{
  EList<B> list1;
  Elist<b> list2;
Class B{
My problem is that I would like to know, for a given instance of B, whether it belongs to list1 or list2 in the container instance A.
Of course, i could simply iterate through list1 and check if my instance of B is part of it. Since it could only be either part of list1 or list2, if it's not present in list1 i can deduce that it's part of list2.
However, this solution seems to be the least effective choice. So I thought having a boolean attribute isInList1 in B that gets set when I add an instance of B to an instance of A.
Going through the generated code, the only place I found to be able to do this is in eSet() (in the switch statement). Am I right?
If so, should I override the eSet method (@generated NOT)? I am worrying that if my model evolves and I change class A, say adding a couple of attributes, EMF won't generate the new eSet() and I could end up with hard to find bugs.
Do you guys could give me any advice on how to do this properly?
Thanks a lot!
Anis
[Updated on: Wed, 13 June 2012 15:30]
Report message to a moderator
Re: Override eSet()... Should I? [message #885787 is a reply to message #885782] Wed, 13 June 2012 15:35 Go to previous messageGo to next message
Anis,
Comments below.
On 13/06/2012 5:28 PM, Anis B. wrote:
> Hi all EMFers!
> Class A{
> EList<B> list1;
> Elist<b> list2;
> Class B{
These are containment lists I guess. EObject.eContainmentFeature will
return whether it belongs to the feature for list 1 or 2.
> part of list2.
No, lists have all their own internal methods; after all, you can add
directly to the list.
Yes, not generally a good idea.
I think EObject.eContainmentFeature should be sufficient.
> Thanks a lot!
> Poissy
Re: Override eSet()... Should I? [message #885795 is a reply to message #885787] Wed, 13 June 2012 15:56 Go to previous message
Member
That did the trick! Wasn't aware of that method...
Thanks a lot Ed!
Previous Topic:EMF Development Environment
Next Topic:XMI:ID attributed to several objects ?
Current Time: Sat Jun 23 15:34:35 GMT 2018
Powered by FUDForum. Page generated in 0.02107 seconds
