Home » Archived » Test and Performance Tools Platform (TPTP) » Log view extension point
Log view extension point [message #116991] Fri, 02 November 2007 09:45 Go to next message
Prasad Kumbhare is currently offline Prasad KumbhareFriend
is it possible to extend log view? what is the extension point for it.
i have defined custom attributes in my log adapter using extended data
elements. I want to display them in log view as column information.
Thanks in advance.
Prasad
Re: Log view extension point [message #117412 is a reply to message #116991] Tue, 06 November 2007 23:39 Go to previous messageGo to next message
Alex Nan is currently offline Alex NanFriend
Hi Prasad,
the log view doesn't support adding custom columns but we are are working on
the feature https://bugs.eclipse.org/bugs/show_bug.cgi?id=200139 which will
allow consumers to add additional function or replace the entire log view
with their implementation. You could potentially be able to extend the log
view by the end of TPTP4.5 but you would have to add the additional columns
in your own enhanced log view. There is no plan to add the extension that
you are asking about.
Kind regards,
Alex Nan.
"prasad" <prasad.kumbhare@gmail.com> wrote in message
news:36965824d5a36af21a136cfdf0a70638$1@www.eclipse.org...
> Thanks in advance.
> Prasad
Re: Log view extension point [message #117968 is a reply to message #117412] Mon, 12 November 2007 10:30 Go to previous message
Thanks Alex for the information.
Previous Topic:Customized Outputter class
Next Topic:Substitution of Datapool contents with Deployment?
Current Time: Mon Jan 22 20:37:27 GMT 2018
Powered by FUDForum. Page generated in 0.01838 seconds
