Home » Newcomers » Newcomers » eclipse installation location
eclipse installation location [message #883149] Thu, 07 June 2012 23:31 Go to next message
exquisitus is currently offline exquisitusFriend
I noticed that each Eclipse Package(C,Java,PHP, and etc.) uses the same
root installation directory: eclipse
Can all the Eclipse Packages be installed in the same root installation
directory without conflict?
Thanks, Tracey
Re: eclipse installation location [message #883200 is a reply to message #883149] Fri, 08 June 2012 03:08 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
No, specifically you should not simply unzip one over another. Start with the one of them that fits best and then use the Install New Software facility in the Help menu to add what you want to add.
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:parser
Next Topic:eclipse Helios
Current Time: Sun Feb 25 14:25:18 GMT 2018
Powered by FUDForum. Page generated in 0.03268 seconds
