Home » Eclipse Projects » Eclipse Platform » PropertyTester: Want to determine does my Project have my custom nature
PropertyTester: Want to determine does my Project have my custom nature [message #882964] Thu, 07 June 2012 14:37 Go to next message
Marjan Stojanovic is currently offline Marjan StojanovicFriend
I have problem from restricting my label to be visible when i select some project in project explorer. I want it to be visible only when selected project doesnt have my custom nature using Property Tester (if u know some other, easier way im open for new solutions).
This is my property Tester extension point:
<extension
point="org.eclipse.core.expressions.propertyTesters">
<propertyTester
class="plugin.plugintests.ProjectNatureTester"
id="plugin.plugintests.natureTester"
namespace="my.plugintests"
properties="changeNature"
type="org.eclipse.core.resources.IResource">
</propertyTester>
</extension>
and this is how i use it:
<visibleWhen
checkEnabled="false">
<with
variable="activeMenuSelection">
<iterate
ifEmpty="false"
operator="or">
<test
property="my.plugintests.changeNature">
</test>
</iterate>
</with>
</visibleWhen>
*********************************************** Class implementation
protected static final String PROJECT_NATURE = "changeNature";
public boolean test(final Object receiver, final String property, final Object[] args, final Object expectedValue) {
// TODO Auto-generated method stub
System.out.println("Usao sam u test");
boolean temp;
if (!(receiver instanceof IResource)) {
temp = false;
System.out.println("Prvi IF: " + temp);
return temp;
if (property.equals(PROJECT_NATURE)) {
final IProject proj = (IProject) receiver;
try {
temp = proj != null && proj.isAccessible() && proj.hasNature(toString(expectedValue));
System.out.println("Drugi IF: " + temp);
return temp;
} catch (final CoreException e) {
temp = false;
System.out.println("Catch: " + temp);
return temp;
System.out.println("Krajnji return false");
return false;
The problem is also that i dont have any messages printed in my console... I also tryed with forcePluginActivation but it didnt help. Also tryed:
<test
property = "org.eclipse.core.resources.projectNature"
value = "id of my custom nature"
</test>
but it didnt want also to work.
Re: PropertyTester: Want to determine does my Project have my custom nature [message #883454 is a reply to message #882964] Fri, 08 June 2012 15:09 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
What kind of project were you selecting? Was it in the Package Explorer?
PW
Re: PropertyTester: Want to determine does my Project have my custom nature [message #885524 is a reply to message #883454] Wed, 13 June 2012 07:18 Go to previous messageGo to next message
yes, its in package explorer
Re: PropertyTester: Want to determine does my Project have my custom nature [message #885679 is a reply to message #885524] Wed, 13 June 2012 12:34 Go to previous messageGo to next message
There is a property tester already available to test project natures, see http://wiki.eclipse.org/Command_Core_Expressions#Property_Testers
But even in your case, java projects would be IJavaProjects, not IResources. Try using something like:
<with variable="activeMenuSelection">
  <iterate ifEmpty="false">
    <adapt type="org.eclipse.core.resources.IResource">
      <test ..../>
    </adapt>
  </iterate>
</with>
PW
Re: PropertyTester: Want to determine does my Project have my custom nature [message #892413 is a reply to message #882964] Thu, 28 June 2012 07:36 Go to previous message
thank you paul, although i saw that wiki a months ago i didnt realise till now how it does functioning Smile
it finished job! Smile
Previous Topic:Eclipse Jobs API using thread pools?
Next Topic:.lock file has expiry date or not?
Current Time: Mon May 21 13:10:23 GMT 2018
Powered by FUDForum. Page generated in 0.03244 seconds
