Home » Language IDEs » Java Development Tools (JDT) » Re: Using JUnit @Rule with Eclipse's test runner
Re: Using JUnit @Rule with Eclipse's test runner [message #882861] Thu, 07 June 2012 10:35
Dani Megert is currently offline Dani MegertFriend
On 21.05.2012 18:02, Eric Rizzo wrote:
> Eclipse 3.7.2
> I just implemented an @Rule in some JUnit 4 tests, but when I run them
> in Eclipse the MethodRule methods are not being called. It's like the
> Eclipse test runner doesn't recognize the @Rule implementations and
> doesn't do anything special with fields that are annotated with @Rule.
> Is there some trick? Does Eclipse simply not support JUnit Rules?
Please file a bug report against JDT UI with a simple test case.
Dani
> Info on the @Rule annotation: http://junit.org/node/580
Previous Topic:Declared package does not match expected package
Next Topic:ClassNotFoundException
Current Time: Mon Apr 23 17:54:00 GMT 2018
Powered by FUDForum. Page generated in 0.01470 seconds
