Home » Eclipse Projects » Eclipse Platform » Eclipse error : SHA-1 not available(Eclipse crashes)
icon13.gif  Eclipse error : SHA-1 not available [message #882640] Wed, 06 June 2012 22:45 Go to next message
Binoy Babu is currently offline Binoy BabuFriend
index.php/fa/10107/0/
I use Ubuntu 12.04 and Eclipse Indigo. After updating my Ubuntu Eclipse no longer works.
An error has occurred.  See the log file
/home/binoy/.eclipse/org.eclipse.platform_3.7.0_155965261/configuration/1339022492430.log
Here's the content of /home/binoy/.eclipse/org.eclipse.platform_3.7.0_155965261/configuration/1339022492430.log :
$ cat /home/binoy/.eclipse/org.eclipse.platform_3.7.0_155965261/configuration/1339022492430.log
!SESSION Thu Jun 07 04:11:32 IST 2012 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2012-06-07 04:11:32.441
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.InternalError: internal error: SHA-1 not available.
	at sun.security.provider.SecureRandom.init(SecureRandom.java:105)
	at sun.security.provider.SecureRandom.<init>(SecureRandom.java:84)
	at java.security.SecureRandom.getDefaultPRNG(SecureRandom.java:186)
	at java.security.SecureRandom.<init>(SecureRandom.java:150)
	at java.io.File$LazyInitialization.<clinit>(File.java:1681)
	at java.io.File.generateFile(File.java:1694)
	at java.io.File.createTempFile(File.java:1803)
	at org.eclipse.equinox.launcher.Main.canWrite(Main.java:1290)
	at org.eclipse.equinox.launcher.Main.checkConfigurationLocation(Main.java:691)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:568)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
What's going on? How can I fix this?
[Updated on: Wed, 06 June 2012 22:47]
Report message to a moderator
Re: Eclipse error : SHA-1 not available [message #888651 is a reply to message #882640] Mon, 18 June 2012 12:25 Go to previous messageGo to next message
Vikram Thakur is currently offline Vikram ThakurFriend
I have got the same issue in an AMD64 machine (Ubuntu 12.04). and solved it by a workaround:
copy: files containing '3740' in /usr/lib/jni/libswt-*3740.so to ~/.swt/lib/linux/x86_64/
But, be sure the packages : libswt-gtk-3-java & libswt-gtk-3-jni are installed.
sudo apt-get install libswt-gtk-3-jni libswt-gtk-3-java
And
sudo cp /usr/lib/jni/libswt-*3740.so ~/.swt/lib/linux/x86_64/
if you have a 32 bits based system : sudo cp /usr/lib/jni/libswt-*3740.so ~/.swt/lib/linux/x86/
Re: Eclipse error : SHA-1 not available [message #1017269 is a reply to message #888651] Mon, 11 March 2013 12:06 Go to previous message
Mehdi BENNIS is currently offline Mehdi BENNISFriend
it works for me thx.
Previous Topic:CNF: Project has always children
Next Topic:"There is no disk in the drive." warning message
Current Time: Sat May 26 02:37:33 GMT 2018
Powered by FUDForum. Page generated in 0.01436 seconds
