Home » Language IDEs » ServerTools (WTP) » JavaScript Formatter(White Space After Opening Paren in for)
JavaScript Formatter [message #882106] Tue, 05 June 2012 21:30 Go to next message
Jeff Wald is currently offline Jeff WaldFriend
I've got Indigo installed, and am trying to adjust my JavaScript formatter settings to prevent a space from being added after the opening parenthesis in a for statement.
When I export my current settings for my formatter, and examine the values, I see this particular value:
<setting id="org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_for" value="do not insert"/>
When I attempt to format my JavaScript, my "for" statements continue having a space added after the opening parenthesis.
It seems like a problem with the formatter (the other settings for the "for" statement appear to work as expected).
Can anyone confirm this is broken, or are my expectations incorrect?
FWIW, here is a sample statement this is being incorrectly formatted:
for ( var i = 0; i < keySplit.length; i++) { }
Thanks! Jeff.
Re: JavaScript Formatter [message #882551 is a reply to message #882106] Wed, 06 June 2012 17:49 Go to previous messageGo to next message
Nitin Dahyabhai is currently online Nitin DahyabhaiFriend
That's the JDT formatter preference for Java, not the JSDT preference for JavaScript.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: JavaScript Formatter [message #882575 is a reply to message #882551] Wed, 06 June 2012 18:59 Go to previous messageGo to next message
Ahhh...that line was from when I was grasping at straws, trying to make it work...the real line was this:
<setting id="org.eclipse.wst.jsdt.core.formatter.insert_space_after_opening_paren_in_for" value="do not insert"/>
Giving me the same error....any other thoughts, Nitin?
Re: JavaScript Formatter [message #882915 is a reply to message #882575] Thu, 07 June 2012 13:20 Go to previous messageGo to next message
Bug? And a rather odd one at that.
Nitin Dahyabhai
Re: JavaScript Formatter [message #882926 is a reply to message #882915] Thu, 07 June 2012 13:32 Go to previous messageGo to next message
Okay, thank you for taking a look. I was going to open a bug report, but wanted another set of eyes to help verify that it really does seem to be a problem. Admittedly, it's not a big problem, but I'm trying to set up an SDE for a team, and JSLint has flagged that extra space after the opening paren as something to be fixed -- and I'd rather not have to start telling folks to disregard various JSLint warnings if I don't have to. For now, I'll tell my team it's a known issue....Thank you for your time!
Jeff.
Re: JavaScript Formatter [message #884664 is a reply to message #882926] Mon, 11 June 2012 15:20 Go to previous messageGo to next message
> time!
It's not a known issue until you file the bug report.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Re: JavaScript Formatter [message #886338 is a reply to message #884664] Thu, 14 June 2012 18:53 Go to previous message
Scott Hunter is currently offline Scott HunterFriend
Bug reports for this have already been filed:
357457
369785
Previous Topic:Can't get my web applications to deploy to Tomcat
Next Topic:Eclipse - JBoss Development problem
Current Time: Tue Jun 19 00:49:54 GMT 2018
Powered by FUDForum. Page generated in 0.01615 seconds
