Home » Eclipse Projects » XML Schema Definition (XSD) » Inline embedded Schema(Inline embedded Schema)
Inline embedded Schema [message #881252] Mon, 04 June 2012 08:20 Go to next message
Sasi Varnan Sundarakandasamy is currently offline Sasi Varnan SundarakandasamyFriend
How can I load an inline embedded schema as XSDSchema?
I have a model which can have any contents inside. Similar to the WSDL types, I want to inline the schema definitions there. If I declare a schema in it, I want the EMFResource to load it as XSDSchema element. Currently all my elements are loaded as XSDAnyType elements.
Please suggest.
Re: Inline embedded Schema [message #881320 is a reply to message #881252] Mon, 04 June 2012 10:30 Go to previous messageGo to next message
Sasi,
Comments below.
What's it embedded in?
The best you can do is use XSDResourceImpl to load the whole resource;
it will scan the DOM for xsd:schema elements and build XSDSchema
instances from them. The XSD model needs be built from a DOM; the SAX
parsing used by XMLResourceImpl/XMIResourceImpl won't suffice.
> Please suggest.
Re: Inline embedded Schema [message #881836 is a reply to message #881320] Tue, 05 June 2012 10:45 Go to previous messageGo to next message
Hi Ed,
Thanks for the input. I tried loading my file with the XSDResourceImpl and called the getSchema, but i am getting some exception logged in the cosole. Sample content attached
I am gtting the following error
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=0, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:352)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java:1576)
at org.eclipse.xsd.impl.XSDSchemaImpl.traverseToRootForPatching(XSDSchemaImpl.java:1529)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.changeAttribute(XSDConcreteComponentImpl.java:1183)
at org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchemaImpl.java:2467)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDConcreteComponentImpl.java:1154)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElementGen(XSDConcreteComponentImpl.java:2791)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElement(XSDConcreteComponentImpl.java:2822)
at org.eclipse.xsd.impl.XSDSchemaImpl.setElement(XSDSchemaImpl.java:2601)
at org.eclipse.xsd.impl.XSDSchemaImpl.createMetaSchema(XSDSchemaImpl.java:538)
at org.eclipse.xsd.util.XSDResourceImpl.handleSchemaElement(XSDResourceImpl.java:833)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:702)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:796)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSchemaImpl.java:665)
at org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl.handleNewBaseTypeDefinition(XSDSimpleTypeDefinitionImpl.java:1677)
at org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl.reconcileAttributes(XSDSimpleTypeDefinitionImpl.java:1625)
  • Attachment: types.xml
    (Size: 0.71KB, Downloaded 214 times)
Re: Inline embedded Schema [message #881896 is a reply to message #881836] Tue, 05 June 2012 12:56 Go to previous messageGo to next message
What version of XSD are you using? Maybe you want to try with the
namespace used in the final 1.0 specification.
http://www.w3.org/2001/XMLSchema
On 05/06/2012 12:45 PM, Sasi Varnan Sundarakandasamy wrote:
> Hi Ed,
Re: Inline embedded Schema [message #881963 is a reply to message #881896] Tue, 05 June 2012 14:53 Go to previous message
Hi Ed,
The change of namespace worked. Thanks again.
Thanks & Regards
Sasi Varnan
Previous Topic:Include several XSD files
Next Topic:Defining type for specific Occrrance of the element.
Current Time: Wed Apr 25 11:02:50 GMT 2018
Powered by FUDForum. Page generated in 0.01785 seconds
