Add menu item to menu at runtime [message #881071] |
Sun, 03 June 2012 20:46 |
Lisi Blümelhuber Messages: 5 Registered: June 2012 |
Junior Member |
I need to create a submenu which is filled with elements at runtime.
I didn't find any examples or any easy way to do it, so I've implemented it via a crude "iterate over menus to find the correctly named menu, and then add MMenuElements to it".
Corresponding code in the handler:
@PostConstruct
public void init() {
for (final String filename : Constants.recentlyUsedFilesList) {
DynamicMenuHelper.addMenuItemToMenu(application, "recentfiles.menu",
filename, "bundleclass://handlers.file.RecentFilesHandler");
@PreDestroy
public void cleanup() {
DynamicMenuHelper.removeMenuItemFromMenu(application, "recentfiles.menu", filename);
This correctly adds the MMenuElements to the menu and seemingly also removes them, but obviously the state gets saved before the @PreDestroy method is called (I mean the "runtime" folder in the Eclipse workspace), so the menu elements don't get removed and multiply each time the application starts.
Can anyone point me in the right direction to do this?
Re: Add menu item to menu at runtime [message #881081 is a reply to message #881071] |
Sun, 03 June 2012 21:20 |
Lisi Blümelhuber wrote on Sun, 03 June 2012 23:46
Use MMenuFactory to create the elements and then add or remove them to the children of the parent menu.
//creation
MDirectMenuItem dynamicItem = MMenuFactory.INSTANCE.createDirectMenuItem();
dynamicItem.setLabel("Testing");
//addition
menu.getChildren().add(dynamicItem);
where menu is the parent MMenu
Re: Add menu item to menu at runtime [message #881102 is a reply to message #881081] |
Sun, 03 June 2012 22:46 |
Junior Member |
I do exactly that, and adding works fine.
It's removing items that doesn't work - the function marked with @PreDestroy gets executed and the list (of the menu children) gets reduced as I intend, but when I start the application again, the menu items that should have been removed are still there, plus one full set of new menu items.
Only way to avoid this is to manually delete the "runtimeXYZ" folder in the Eclipse workspace.
MMenu target = (MMenu) findMenuElement(application, menuElementId);
List<MMenuElement> elements = target.getChildren();
List<MMenuElement> found = new ArrayList<MMenuElement>();
for (MMenuElement element: elements) {
if (element.getLabel() != null && element.getLabel().equals(menuItemLabel)) {
found.add(element);
target.getChildren().removeAll(found);
[Updated on: Sun, 03 June 2012 22:49] Report message to a moderator
Re: Add menu item to menu at runtime [message #881106 is a reply to message #881102] |
Sun, 03 June 2012 22:58 |
On your run configuration -> main tab -> check 'Clear' and select 'workspace' -> apply
However it looks like when you remove the items, they don't get removed from the model and when the app runs again it loads the model which the previous launch left with the items in the model.
Re: Add menu item to menu at runtime [message #881503 is a reply to message #881346] |
Mon, 04 June 2012 17:39 |
Junior Member |
First of all, thanks for your input so far!
Sopot Cela wrote on Sun, 03 June 2012 18:58On your run configuration -> main tab -> check 'Clear' and select 'workspace' -> apply
Clearing the workspace works, but my impression is exactly what you wrote in your last sentence - the model stays the same, and that's unacceptable for the release application.
Christoph Keimel wrote on Mon, 04 June 2012 03:54maybe you could remove the menu items on @PersistState instead of @PreDestroy?
I tried that, but the method then does not get called at exiting the application.
Brian de Alwis wrote on Mon, 04 June 2012 07:34... Checking or and removing the old menu on startup is likely your best option for now.
Do you mean the menu where I want to put the dynamically generated menu items into or the menu items?
When I simply remove the menu items from the menu target.getChildren().clear(); , on first click on one of the menu items I get a fat stacktrace with no functions of my own involved - after that, the menu items in the menu are unlabeled and throw further exceptions or do nothing when being clicked.
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem.getExecutionContext(DirectContributionItem.java:476)
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem.executeItem(DirectContributionItem.java:450)
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem.handleWidgetSelection(DirectContributionItem.java:360)
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem.access$1(DirectContributionItem.java:344)
at org.eclipse.e4.ui.workbench.renderers.swt.DirectContributionItem$2.handleEvent(DirectContributionItem.java:301)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1021)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:915)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
I really thought that implementing a "recent files" menu would be a very simple feature to implement - maybe I'm overlooking something terribly obvious (this framework is new to me)?
FUDForum. Page generated in 0.04934 seconds
