Home » Eclipse Projects » Eclipse 4 » MDirtyable usage
MDirtyable usage [message #880029] Fri, 01 June 2012 09:55 Go to next message
Mauro Condarelli is currently offline Mauro CondarelliFriend
Hi I'm trying to rewrite my app in pure e4.
Application is an editor for a non-trivial EMF model.
I've found MDirtyable that seems the "Right Way" to track dirty status
in e4.
Unfortunately MDirtyable seems to be tied to a MPart, while I would need
to tie it to a more global structure (TrimmedWindow? Application?) since
my MParts edit single facets of the whole model.
Am I missing something?
Mauro
Re: MDirtyable usage [message #880038 is a reply to message #880029] Fri, 01 June 2012 10:14 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
This no different to e3 - and application is considered dirty if at
least on of its part is dirty.
Tom
Am 01.06.12 11:55, schrieb Mauro Condarelli:
> in e4.
> Mauro
Re: MDirtyable usage [message #880066 is a reply to message #880038] Fri, 01 June 2012 11:00 Go to previous messageGo to next message
Phill Perryman is currently offline Phill PerrymanFriend
You could get all your MParts to register for IEventBroker messages and then send ModelDirty and ModelSaved messages. Then each MPart can set or clear its own MDirtyable as needed. If you have multiple models open at the same time it might be easier to add a listener list to the model so each part registers with its own model.
Re: MDirtyable usage [message #880083 is a reply to message #880066] Fri, 01 June 2012 11:41 Go to previous messageGo to next message
Sorry,
I was not clear.
My app edits a single EMF model (singleton).
I already track dirty status in the model itself using CommandStack
status and update (manually) the Resource "Modified" status.
IMHO this is the only place where the dirty info is kept.
Should I duplicate it in all MParts?
Is there some way to get a "global" (i.e.: not connected to a single
MPart) MDirtyable?
What is the e4-correct way to handle this?
Re: MDirtyable usage [message #880085 is a reply to message #880083] Fri, 01 June 2012 11:49 Go to previous message
> Sorry,
> I was not clear.
> MPart) MDirtyable?
An afterthought:
I'm using e4 MParts like I was using Views in e3, is this correct?
Should I do something different?
Previous Topic:Binding Contexts and Binding Tables
Next Topic:Autosave
Current Time: Wed May 23 17:03:34 GMT 2018
Powered by FUDForum. Page generated in 0.02132 seconds
