Home » Eclipse Projects » WindowBuilder » XWT XML Schema
XWT XML Schema [message #879672] Thu, 31 May 2012 16:04 Go to next message
Charles anon is currently offline Charles anonFriend
Any pointers? The only one I could find is dated 2009:
bugsDOTeclipseDOTorg/bugs/show_bugDOTcgi?id=260289
Re: XWT XML Schema [message #879884 is a reply to message #879672] Fri, 01 June 2012 03:39 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric ClaybergFriend
This appears to have been posted to the wrong forum.
I don't see what this has to do with WindowBuilder.
Re: XWT XML Schema [message #879971 is a reply to message #879672] Fri, 01 June 2012 08:06 Go to previous messageGo to next message
WindowsBuilder includes XWT, thus my hopes that someone out there might be using the two together (like me) and have the information I'm looking for. (The XWT mailing list appears to be inactive)
[Updated on: Fri, 01 June 2012 08:22]
Report message to a moderator
Re: XWT XML Schema [message #880013 is a reply to message #879971] Fri, 01 June 2012 09:26 Go to previous messageGo to next message
I think I have found a possible source:
gitDOTeclipseDOTorg/c/e4/orgDOTeclipseDOTe4DOTxwtDOTgit/
Re: XWT XML Schema [message #880041 is a reply to message #880013] Fri, 01 June 2012 10:21 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
There can't be a schema for something like XWT, XAML, ... it is a
serialisation specification of a Object-Graph.
Tom
Am 01.06.12 11:26, schrieb Charles anon:
Re: XWT XML Schema [message #880204 is a reply to message #879971] Fri, 01 June 2012 16:17 Go to previous messageGo to next message
Charles anon wrote on Fri, 01 June 2012 04:06
This is not an XWT forum, so questions about XWT that are not directly related to WB are not appropriate for this forum. Sorry.
Re: XWT XML Schema [message #882470 is a reply to message #880204] Wed, 06 June 2012 14:13 Go to previous messageGo to next message
If there was an XWT forum of course I'd post there first. It seemed reasonable to default to this forum given I wished to use WindowsBuilder but required a meta-model with which I could transform my work over to this graphical editor. XWT seemed like a solution, and having found a XSD file from 2009 it seemed plausible there might be a more recent version.
Re: XWT XML Schema [message #882542 is a reply to message #882470] Wed, 06 June 2012 17:22 Go to previous message
XWT is part of the e4 project, so the e4 forum would be the correct place to ask XWT related questions.
None of us on the WB team are XWT experts (or even users of XWT) so we can't help you with this kind of question. We can help you with the XWT-specific parts of WindowBuilder (e.g., the WB XWT palette, code gen, etc.). Any questions concerning the XWT libraries themselves or their runtime behavior should be addressed to the e4 forum.
Previous Topic:add properties with two arguments
Next Topic:JPanel background color as a resource property
Current Time: Wed Apr 25 03:21:51 GMT 2018
Powered by FUDForum. Page generated in 0.01914 seconds
