Home » Modeling » OCL » Problems parsing ocl query
Problems parsing ocl query [message #879127] Wed, 30 May 2012 15:08 Go to next message
Andreas Burger is currently offline Andreas BurgerFriend
i get strange problem with the ocl parser.
I want to parse a query which uses the method getAppliedStereotypes in it. When i parse it with the OCL class i get the following error:
org.eclipse.ocl.SemanticException: Cannot find operation (getAppliedStereotype(String)) for the type ...
The context for this query is a Class so it should have this function.
The other strange thing is, if the query is executed in the interactive ocl console it works fine.
Does anybody know this error and why it raises?
Andreas
Re: Problems parsing ocl query [message #879161 is a reply to message #879127] Wed, 30 May 2012 16:21 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
These obscure problems are very difficult to helop with without some detail.
There are at least three relevant "Class" classes that I am aware of.
There are at least three relevant "OCL" classes that I am aware of.
Not knowing what you're doing, I cannot help further.
I suggest a zipped project demonstrating the failure, if you want any
chance of a prompt response.
Ed Willink
On 30/05/2012 16:08, Andreas Burger wrote:
> Andreas
Re: Problems parsing ocl query [message #879414 is a reply to message #879161] Thu, 31 May 2012 07:26 Go to previous messageGo to next message
thank you for your fast respond. I added a zipped eclipse project which demonstrating the error.
It contains an uml model with MARTE and SysML stereotypes in it, a model loader class, a ocl parser class and a test class.
Running the test class the uml model will be loaded and the constraint in the uml model will be parsed.
Thank you for your support.
Andreas
  • Attachment: example.zip
    (Size: 891.24KB, Downloaded 207 times)
[Updated on: Thu, 31 May 2012 07:31]
Report message to a moderator
Re: Problems parsing ocl query [message #879634 is a reply to message #879161] Thu, 31 May 2012 14:59 Go to previous messageGo to next message
Carsten Reckord is currently offline Carsten ReckordFriend
I happened to stumble over the exact same problem just now. The issue is the
UML metamodel used by the UML OCL engine, which is loaded from
UMLResource.UML_METAMODEL_URI (pathmap://UML_METAMODELS/UML.metamodel.uml) [1].
Since UML2 4.0.0, this model no longer seems to contain the non-normative
operations like getAppliedStereotypes, hasKeyword, etc.
I was only able to find these in
platform:/plugin/org.eclipse.uml2.uml/model/UML.uml
So my questions would be:
1) Which of these models should be used by the OCL UML plugin or other
consumers of the UML metamodel?
2) If the one currently used (i.e. without those operations) is the right
one, how else can these features be accessed in OCL?
[3) What's the rationale behind removing those operations in the first place?]
Carsten
[1] cf. org.eclipse.ocl.uml.UMLEnvironmentFactory.getUMLMetamodel()
On 30.05.2012 18:21, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Regards,
>> Andreas
Re: Problems parsing ocl query [message #879645 is a reply to message #879634] Thu, 31 May 2012 15:19 Go to previous messageGo to next message
Minor correction:
Actually, platform:/plugin/org.eclipse.uml2.uml/model/UML.merged.uml seems
to be an even better choice...
Re: Problems parsing ocl query [message #879697 is a reply to message #879634] Thu, 31 May 2012 16:57 Go to previous messageGo to next message
Oh *****! Thanks for diagnosing this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=381237 raised.
Ed Willink
On 31/05/2012 15:59, Carsten Reckord wrote:
> Best regards,
> Carsten
>> Hi
>> Regards
>> Ed Willink
>>> Hi,
>>> Regards,
>>> Andreas
Re: Problems parsing ocl query [message #879698 is a reply to message #879645] Thu, 31 May 2012 16:59 Go to previous messageGo to next message
HI
Unfortunately org.eclipse.uml2.uml artefacts are private and omitted
from the binary distribution. You have to use GIT to get them.
The public artefacts are in org.eclipse.uml2.uml.resources.
Ed Willink
On 31/05/2012 16:19, Carsten Reckord wrote:
> Minor correction:
Re: Problems parsing ocl query [message #879941 is a reply to message #879698] Fri, 01 June 2012 06:59 Go to previous messageGo to next message
so, if i understand correctly, it exists no workaround for this problem?
Andreas
Re: Problems parsing ocl query [message #879997 is a reply to message #879941] Fri, 01 June 2012 08:58 Go to previous message
That is why https://bugs.eclipse.org/bugs/show_bug.cgi?id=381237 has
been raised and there is some urgency to finding a solution.
Carsten's observation suggest that using the file from GIT is a workaround.
Ed Willink
On 01/06/2012 07:59, Andreas Burger wrote:
> Andreas
Previous Topic:Ocl expressions
Next Topic:OCL + eGenericType
Current Time: Thu Feb 22 17:24:39 GMT 2018
Powered by FUDForum. Page generated in 0.01694 seconds
