Home » Modeling » ATL » Ecore 2 Ecore using ATL ->output java objects
Ecore 2 Ecore using ATL ->output java objects [message #879014] Wed, 30 May 2012 07:16 Go to next message
Kosala Yapa is currently offline Kosala Yapa
Hi there,
I do ecore model to ecore model transformation using ATL.
Input: aa.xmi
Meta Model: source.ecore
Transformation using ATL
Output: bb.xmi
Meta Model: target.ecore
Problem: The above transformation creates bb.xmi as an output. I know it is possible to read bb.xmi and create java objects in memory. I do not like this approach.
Is it possible to directly create java objects as output in memory instead of above bb.xmi? How can i do that?
Thanks in advance.
Kosala
Re: Ecore 2 Ecore using ATL ->output java objects [message #879059 is a reply to message #879014] Wed, 30 May 2012 08:55 Go to previous messageGo to next message
I'm pretty sure that ATL works with Java objects and then just saves
them to create the XMI fole, so if you use a Java launch you can access
the output resource to obtain the objects.
Ed Willink
On 30/05/2012 12:16, Kosala Yapa wrote:
> Hi there,
> Input: aa.xmi
> Output: bb.xmi
> Thanks in advance.
> Kosala
Re: Ecore 2 Ecore using ATL ->output java objects [message #881939 is a reply to message #879059] Tue, 05 June 2012 10:21 Go to previous messageGo to next message
Hi Willink,
Here is the java launch, which creates output.xmi. I am trying to find a way to capture java objects in memory.
package org.eclipse.m2m.atl.launch.files;
import java.io.IOException;
import java.io.InputStream;
import java.net.URL;
import java.util.HashMap;
import java.util.Map;
import java.util.Properties;
import java.util.Map.Entry;
import org.eclipse.core.runtime.FileLocator;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.core.runtime.Path;
import org.eclipse.core.runtime.Platform;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.m2m.atl.common.ATLExecutionException;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.IExtractor;
import org.eclipse.m2m.atl.core.IInjector;
import org.eclipse.m2m.atl.core.IModel;
import org.eclipse.m2m.atl.core.IReferenceModel;
import org.eclipse.m2m.atl.core.ModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.launch.ILauncher;
import org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher;
import target.Device;
import target.TargetPackage;
public class Tpf3 {
private Properties properties;
protected IModel inModel;
protected IModel outModel;
try {
Tpf3 runner = new Tpf3();
runner.loadModels("tpfIN.xmi");
runner.doTpf3(new NullProgressMonitor());
runner.saveModels("tpfOut.xmi");
} catch (ATLCoreException e) {
e.printStackTrace();
} catch (IOException e) {
} catch (ATLExecutionException e) {
}//end main()
public Tpf3() throws IOException {
properties = new Properties();
properties.load(getFileURL("Tpf3.properties").openStream());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
//System.out.println(properties);
public void loadModels(String inModelPath) throws ATLCoreException {
ModelFactory factory = new EMFModelFactory();
IInjector injector = new EMFInjector();
IReferenceModel sourceMetamodel = factory.newReferenceModel();
injector.inject(sourceMetamodel, getMetamodelUri("source"));
IReferenceModel targetMetamodel = factory.newReferenceModel();
injector.inject(targetMetamodel, getMetamodelUri("target"));
this.inModel = factory.newModel(sourceMetamodel);
injector.inject(inModel, inModelPath);
this.outModel = factory.newModel(targetMetamodel);
public void saveModels(String outModelPath) throws ATLCoreException {
IExtractor extractor = new EMFExtractor();
extractor.extract(outModel, outModelPath);
public Object doTpf3(IProgressMonitor monitor) throws ATLCoreException, IOException, ATLExecutionException {
ILauncher launcher = new EMFVMLauncher();
Map<String, Object> launcherOptions = getOptions();
launcher.initialize(launcherOptions);
launcher.addInModel(inModel, "IN", "source");
launcher.addOutModel(outModel, "OUT", "target");
return launcher.launch("run", monitor, launcherOptions, (Object[]) getModulesList());
protected InputStream[] getModulesList() throws IOException {
InputStream[] modules = null;
String modulesList = properties.getProperty("Tpf3.modules");
if (modulesList != null) {
String[] moduleNames = modulesList.split(",");
modules = new InputStream[moduleNames.length];
for (int i = 0; i < moduleNames.length; i++) {
String asmModulePath = new Path(moduleNames[i].trim()).removeFileExtension().addFileExtension("asm").toString();
modules[i] = getFileURL(asmModulePath).openStream();
return modules;
protected String getMetamodelUri(String metamodelName) {
return properties.getProperty("Tpf3.metamodels." + metamodelName);
protected InputStream getLibraryAsStream(String libraryName) throws IOException {
return getFileURL(properties.getProperty("Tpf3.libraries." + libraryName)).openStream();
protected Map<String, Object> getOptions() {
Map<String, Object> options = new HashMap<String, Object>();
for (Entry<Object, Object> entry : properties.entrySet()) {
if (entry.getKey().toString().startsWith("Tpf3.options.")) {
options.put(entry.getKey().toString().replaceFirst("Tpf3.options.", ""),
entry.getValue().toString());
return options;
protected static URL getFileURL(String fileName) throws IOException {
final URL fileURL;
if (isEclipseRunning()) {
URL resourceURL = Tpf3.class.getResource(fileName);
if (resourceURL != null) {
fileURL = FileLocator.toFileURL(resourceURL);
} else {
fileURL = null;
} else {
fileURL = Tpf3.class.getResource(fileName);
if (fileURL == null) {
throw new IOException("'" + fileName + "' not found");
} else {
return fileURL;
public static boolean isEclipseRunning() {
try {
return Platform.isRunning();
} catch (Throwable exception) {
// Assume that we aren't running.
return false;
Re: Ecore 2 Ecore using ATL -&amp;gt;output java objects [message #882008 is a reply to message #881939] Tue, 05 June 2012 12:05 Go to previous message
After 5 minutes downloading and installing ATL I can see that
IModel has an EMFModel derived class for which the getResource() method
returns a Resource which is usually full of Java model objects.
Try using the Eclipse tooling to help discover what your coding tools do.
Ed Willink
On 05/06/2012 15:21, Kosala Yapa wrote:
> Hi Willink,
> public class Tpf3 {
> public static void main(String[] args) {
> try {
> }//end main()
> return modules;
> metamodelName);
> ""), entry.getValue().toString());
> return options;
> final URL fileURL;
> } else {
> fileURL = null;
> } else {
> } else {
> return fileURL;
> try {
> return false;
> Thanks
Previous Topic:How to create java objects than creating xmi output in ATL transformation?
Next Topic:BPEL 2 XML using ATL
Current Time: Mon May 20 11:56:17 EDT 2013
Powered by FUDForum. Page generated in 0.03324 seconds
