Home » Language IDEs » ServerTools (WTP) » Caching in M5 With JDK 1.4.2.0x
Caching in M5 With JDK 1.4.2.0x [message #115766] Mon, 04 July 2005 12:25 Go to next message
Alain Marc Pannetier is currently offline Alain Marc PannetierFriend
Dear all,
Resource Caching introduced in M5 is a welcome addition. However I had
(and solved) a weird problem with SUN JDK 1.4.2.06.
Not sure what the root cause is...
If someone can shed some light on that one...
0 - I'm behind a firewall/proxy.
1 - Preferences - I configured my JDKs/JREs, XDoclet, my proxy, re-enabled
caching (I really believe this check box should be unchecked by default).
2 - New Dynamic web project wizard... Stuck. After the usual "fiddling
with settings" delay. Hard kills of Java processes etc... I had to see
things running under debug. So I imported some plugins with source
(namely
- org.apache.xerces
- org.eclipse.wst.common.uriresolver
- org.eclipse.wst.internet.cache
- org.eclipse.wst.internet.proxy
- org.eclipse.wst.validation
- org.eclipse.wst.validation.ui
- org.eclipse.wst.xml.core)
and run the workbench under debug.
All what the internet proxy plugin does is, in the earlyStartup callback,
to
define the wellknown system properties http.proxyHost, http.proxyPort in
various combinations according to the preferences in the prefs store.
That should be good enough.
As it turned out in my 1.4.2.06 JDK at least,
sun.net.www.http.HttpClient.java did not honour correctly these properties
(only with the workbench though, other test programs were doing just fine).
I discovered this weird behaviour once I had rebuilt rt.jar with a version
of HttpClient.java pulled out of the SUN COMMUNITY SOURCE LICENSE distro.
Finally I also installed 1.4.2.08 and everything worked perfectly right
from the start (a little length the first time of course but then XML
validation was lightening fast after once the cache is populated).
I might have done something wrong in the first place but can't really see
what now.
However if anybody experience the same pb, the quick fix is to upgrade to
1.4.2.08 (or another JDK for that matter).
Otherwise, thx to the WTP committers, quality is improving. And I really
love the XSD editor. Now I'll test the JST side...
Alain Pannetier
Re: Caching in M5 With JDK 1.4.2.0x [message #115781 is a reply to message #115766] Mon, 04 July 2005 13:08 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
It is maybe related to java bug 5019401
(http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=5019401) which has been
fixed in JDK 1.4.2_07 ("ServerSocket(Proxy) and Socket(Proxy) do not work
with sun one proxy server").
Csaba
Alain Pannetier wrote:
> Dear all,
> (namely
> - org.apache.xerces
> to
> fine).
> what now.
> Alain Pannetier
Re: Caching in M5 With JDK 1.4.2.0x [message #115970 is a reply to message #115766] Mon, 04 July 2005 19:27 Go to previous message
Lawrence Mandel is currently offline Lawrence MandelFriend
Hi Alain,
re-enabled
Just wanted to point out that bug 88260
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=88260) contains a request
to enable caching by default. This will be addressed for WTP 0.7.
Thanks for the feedback.
Lawrence
Previous Topic:Tomcat and eclipse-like projects structure
Next Topic:Tomcat Directory Structure Layout and Dinamic Web Project
Current Time: Sun May 27 17:38:08 GMT 2018
Powered by FUDForum. Page generated in 0.01891 seconds
