Home » Modeling » TMF (Xtext) » Out of memory during full build
Out of memory during full build [message #878535] Tue, 29 May 2012 13:47 Go to next message
Vishal seth is currently offline Vishal sethFriend
Member
I am facing an OutOfMemory issue during full build of resources in the project. Actually few files are of big size due to which OOM is thrown.
Went through the code & saw it clears the resource set as per the IResourceClusteringPolicy. As per the default policy it checks whether 15% Mb is available or not, otherwise clear the resource set while creating new resource description. As per this policy it does not check the size of the file to be loaded but expects 15% to be available.
Let me know for following stuffs:
- Is there some other way to make a full build?
- How can I inject my own clustering policy or how can i inject minimumPercentFreeMemory. I tried injecting both of them but in vain.
Vishal
Re: Out of memory during full build [message #878544 is a reply to message #878535] Tue, 29 May 2012 13:55 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
please have a look at the extension point org.eclipse.xtext.ui.shared.overridingGuiceModule. (register a module there)
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Out of memory during full build [message #878903 is a reply to message #878544] Wed, 30 May 2012 07:04 Go to previous message
Member
thanks Christian.
Vishal
Previous Topic:Generate Diagramm of EMF out of Xtext??
Next Topic:simplified grammar for autocompletion
Current Time: Mon May 21 21:04:22 GMT 2018
Powered by FUDForum. Page generated in 0.01752 seconds
